3D Design and Management
As well as creating toolpaths directly from 2D drawings, Aspire can produce extremely flexible 3D toolpaths. These toolpaths are created from 3D design elements called 3D Components that can be generated from models created in external 3D design packages , imported as 3D clipart or built entirely from within Aspire using 2D artwork as a source.
The 3D View
The 3D View can show you the current Composite Model
The Composite Model
3D Components and Levels
In Aspire, the aim is to end up with a set of Components and Levels that when combined together will make the finished 3D part. One way to think of this is like building a 3D collage or assembly. As the design evolves, new Levels or shapes may need to be created or existing ones changed. The parts of the collage are managed with the Component Tree
  1. Use a modeling tool to create shapes from 2D vectors.
  2. Import a pre-created 3d model - either a model previously created in Aspire or from another source such as a clipart library or a different modeling package.
  3. Create a 'texture' Component from a bitmap image.
  4. Use the Split Components Tool to break an existing Component into multiple pieces.
Dynamic Properties
Combine Modes
Note:
Add
Subtract
Merge
Low
Level Mirror Modes
  • Left to Right
  • Right to Left
  • Top to Bottom
  • Bottom to Top
  • Top Left Quadrant
  • Top Right Quadrant
  • Bottom Left Quadrant
  • Bottom Right Quadrant
Multi Sided View
