Laser Cut And Fill
Tool Selection
Select Tool
Power
This value sets what proportion of your machines maximum laser power will be used for this toolpath.
Move Speed
No. Passes
The machine can repeat a toolpath a number of times to cut through thicker material. This value sets the number of repeats.
Strategy
Based on the selected vector shapes in your drawing, this toolpath offers four distinct strategies
Cut Outside / Right
Cut Inside / Left
Cut On
This option will runs the center of the laser beam along the selected vector. No offsetting or kerf compensation is required.
Hatch Fill
Allowance
Stepover
Hatch Angle
Cross Hatch
Checking this option will create a cross hatch fill instead of a single set of lines.
Immediate Output
Post Processor
Add side to toolpath name
Output direct to machine
