Importing Full-3D models
A table leg imported from STL file
Overview
  1. Setting-up rotary project
  2. Choosing file for import
  3. Orientating the model in material block
  4. Scaling the model
  5. Finishing the import
Setting up a rotary project
To start the importing process, use Import a Component or 3D Model tool from the Modelling tab
Initial orientation of imported model
mported model distorted in place where rotation axis was outside the model
The same model imported without distortion
Front of the leg aligned with center of the job
3-axis rotary machining, tool correctly positioned
3-axis rotary machining, tool side is touching the stock
Scaling imported model
Table leg after completing orientation and changing units
Finishing import
Raster toolpath with constant stepover is compressed in thinner part of model due to distortion
Importing Flat Models
Initial orientation of imported flat model
