Post Processor Editing
G-Code Output
T1 M6
G17
G0 Z4.5000
G0 X0.0000 Y0.0000 S12000 M3
G0 X2.4567 Y7.8342 Z0.2500
G1 Z-0.0500 F5.0
HPGL Output
IN;PA;
PU2496,7960;
PD2496,7960;
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
PU2496,7960;
PU2496,6096;
Post Processor Sections
File Comments
+ History
+ Who When What
+ Tony 14/07/2006 Written
Global File Statements
Statement
Result
FILE_EXTENSION="txt"
UNITS="MM"
PRINT_DIRECT="YES"
RAPID_PLUNGE_TO_STARTZ="YES"
ROTARY_WRAP_Y=A
ROTARY_WRAP_X=B
Tape Splitting Support
For example a command of:
would lead to...
Output will be split into multiple files of a maximum of 1000 lines (+ however many lines in there are within the footer section of the post processor), if a retract move exists after line 900 (1000 – 100), the file will be split at that move. If the file was called "toolpath" the split files would be named toolpath_1.tap, toolpath_2.tap etc. The first toolpath output will be "toolpath_ 1.tap" there will be no file named "toolpath" without an index number, (as INDEX_ON_FIRST_FILE= YES is used), unless the file was less than 1000 lines long, in which case the file would not be split.
Line Terminating Characters
LINE_ENDING="[13][12]"
Block Numbering
Statement
Result
LINE_NUMBER=0
LINE_NUMBER_INCREMENT=10
LINE_NUMBER_MAXIMUM=99999
Variables
Variable Name
Output using
Value
Example File
FEED_RATE
[F]
Current Feed Rate.
CUT_RATE
[FC]
Current Cut Feed Rate.
CNCShark-USB_Arcs_inch.pp
PLUNGE_RATE
[FP]
Current Plunge Feed Rate.
SPINDLE_SPEED
[S]
GCode_arc_inch.pp
POWER
[P]
grbl_mm.pp
TOOL_NUMBER
[T]
Current Tool Number.
PREVIOUS_TOOL_NUMBER
[TP]
Previous Tool Number.
NC-Easy.pp
LINE_NUMBER
[N]
Current Line Number in file.
TOOL_NAME
[TOOLNAME]
Name of Current Tool.
MaxNC_inch.pp
TOOL_NOTES
[TOOL_NOTES]
Busellato_Jet3006_arc_inch.pp
TOOLPATH_NAME
[TOOLPATH_NAME]
Name of Current Toolpath.
Viccam_ATC_Arcs_inch.pp
TOOLPATH_FILENAME
[TP_FILENAME]
ez-Router_inch.pp
TOOLPATH_DIR
[TP_DIR]
Woodp_arc_mm.pp
TOOLPATH_EXTENSION
[TP_EXT]
Toolpath File Extension.
TekcelE_Arc_ATC_3D.pp
TOOLPATH_PATHNAME
[PATHNAME]
Toolpath Folder Pathname.
WinPC-NC_ATC_Arcs_mm.pp
X_POSITION
[X]
GCode_arc_inch.pp
Y_POSITION
[Y]
GCode_arc_inch.pp
Z_POSITION
[Z]
GCode_arc_inch.pp
A_POSITION
[A]
ARC_CENTRE_I_INC_POSITION
[I]
ARC_CENTRE_J_INC_POSITION
[J]
ARC_CENTRE_I_ABS_POSITION
[IA]
Isel_arc_mm.pp
ARC_CENTRE_J_ABS_POSITION
[JA]
Isel_arc_mm.pp
ARC_START_X_POSITION
[ArcStartX]
TextOutput_Arcs_mm.pp
ARC_START_Y_POSITION
[ArcStartY]
ARC_MID_X_POSITION
[ArcMidX]
ARC_MID_Y_POSITION
[ArcMidY]
ARC_MID_X_INC_POSITION
[ArcMidXI]
ARC_MID_Y_INC_POSITION
[ArcMidYI]
ARC_RADIUS
[Radius]
The radius of an arc.
Bosch_ATC_Arcs_mm.pp
ARC_ANGLE
[Angle]
The angle of an arc.
Generic HPGL_Arcs.pp
X_HOME_POSITION
[XH]
CAMTech_CMC3_mm.pp
Y_HOME_POSITION
[YH]
CAMTech_CMC3_mm.pp
Z_HOME_POSITION
[ZH]
CAMTech_CMC3_mm.pp
SAFE_Z_HEIGHT
[SAFEZ]
EMC2 Arcs(inch)(*.ngc)
WRAP_DIAMETER
[WRAP_DIA]
X_LENGTH
[XLENGTH]
Length of material in X.
Y_LENGTH
[YLENGTH]
Length of material in Y.
Z_LENGTH
[ZLENGTH]
Length of material in Z.
X_MIN
[XMIN]
MaxNC_inch.pp
Y_MIN
[YMIN]
MaxNC_inch.pp
Z_MIN
[ZMIN]
MaxNC_inch.pp
X_MAX
[XMAX]
MaxNC_inch.pp
Y_MAX
[YMAX]
MaxNC_inch.pp
Z_MAX
[ZMAX]
MaxNC_inch.pp
X_ORIGIN_POS
[X_ORIGIN_POS]
Origin Position in X.
Y_ORIGIN_POS
[Y_ORIGIN_POS]
Origin Position in Y.
Z_ORIGIN
[Z_ORIGIN]
XY_ORIGIN
[XY_ORIGIN]
X, Y Origin.
TOOLS_USED
[TOOLS_USED]
TOOLPATHS_OUTPUT
[TOOLPATHS_OUTPUT]
TOOLPATH_NOTES
[TOOLPATH_NOTES]
FILE_NOTES
[FILE_NOTES]
File Notes (Edit > Notes).
TIME
[TIME]
File creation time.
DATE
[DATE]
File creation date.
DWELL_TIME
[DWELL]
Mach2_3_Arcs_inch.pp
PRODUCT
[PRODUCT]
TOOL_DIAMETER
[TDIA]
Tool diameter.
Format of Variables
where
  • MX = Multiplier Value.
A typical variable
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
VAR
Z_HOME_POSITION
ZH
A
Z
F
1.0
-1
  2. Variable Name.
  3. Equals Sign.
Formatting the Output Value
Flag
Function
Default (without flag)
Left Justify the output
Values are right justified
0
Values is always output with a separator character ( in practive this would only change the output value if the value is set to output integer values only)
Default
Example
VAR LINE_NUMBER = [N|A||1.0]
VAR LINE_NUMBER = [N|A|N|1.0]
VAR FEED_RATE = [F|A||1.0]
VAR PLUNGE_RATE = [FP|A||1.0]
VAR CUT_RATE = [FC|A||1.0]
VAR X_POSITION = [X|A||1.0]
VAR Y_POSITION = [Y|A||1.0]
VAR Z_POSITION = [Z|A||1.0]
VAR X_POSITION = [X|A|X|1.3]
VAR X_POSITION = [X|A|X|1.4]
VAR X_MIN = [XMIN|A||1.3]
VAR Y_MIN = [YMIN|A||1.3]
VAR Z_MIN = [ZMIN|A||1.3]
VAR X_MAX = [XMAX|A||1.3]
VAR Y_MAX = [YMAX|A||1.3]
VAR Z_MAX = [ZMAX|A||1.3]
VAR X_MIN = [XMIN|A|X|1.3]
Multiplier Value
Post Processor Blocks
HEADER
begin HEADER
"Commands"
Home Position Information
  • Home X = [XH]
  • Home Y = [YH]
  • Home Z = [ZH]
  • Tool Number = [T]
  • Tool name = [TOOLNAME]
Initial cutting speeds
Spindle Speed
  • Spindle Speed = [S] R.P.M.
TOOLCHANGE
begin TOOLCHANGE
"Commands"
  • Previous Tool Number = [TP]
  • Tool Number = [T]
NEW_SEGMENT
begin NEW_SEGMENT
"Commands"
INITIAL_RAPID_MOVE
begin INITIAL_RAPID_MOVE
"Commands"
RAPID_MOVE
begin RAPID_MOVE
"Commands"
FIRST_FEED_MOVE
begin FIRST_FEED_MOVE
"Commands"
FEED_MOVE
begin FEED_MOVE
"Commands"
FIRST_CW_ARC_MOVE
begin FIRST_CW_ARC_MOVE
"Commands"
"Commands"
FIRST_CW_HELICAL_ARC_MOVE
"Commands"
CW_ARC_MOVE
begin CW_ARC_MOVE
"Commands"
CW_HELICAL_ARC_MOVE
begin CW_HELICAL_ARC_MOVE
"Commands"
FIRST_CCW_ARC_MOVE
begin FIRST_CCW_ARC_MOVE
"Commands"
"Commands"
"Commands"
CCW_ARC_MOVE
begin CCW_ARC_MOVE
"Commands"
begin CCW_HELICAL_ARC_MOVE
"Commands"
FOOTER
begin FOOTER
"Commands"
Jet Support Sections
JET_TOOL_POWER
begin JET_TOOL_POWER
"Commands"
JET_TOOL_ON
begin JET_TOOL_ON
"Commands"
JET_TOOL_OFF
begin JET_TOOL_OFF
"Commands"
FEED_RATE_CHANGE
begin FEED_RATE_CHANGE
"Commands"
FIRST_PLUNGE_MOVE
begin FIRST_PLUNGE_MOVE
"Commands"
PLUNGE_MOVE
begin PLUNGE_MOVE
"Commands"
RETRACT_MOVE
begin RETRACT_MOVE
"Commands"
DWELL_MOVE
begin DWELL_MOVE
"Commands"
Special Characters
  • [10] Outputs a line feed.
To do this:
POST_NAME =
FILE_EXTENSION =
and alter these accordingly.
FILE_EXTENSION = "tap"
to make them read:
FILE_EXTENSION = "nc"
Tips And Tricks
