License Dialog
Online Method
[object Object]
[object Object]
After logging in here with your V&Co account details another page may appear asking for permission for Cut2D Pro to access your license details.
This page will only appear if you have not already granted access. If this appears you should select "Allow" to enable Cut2D Pro to retrieve your license details automatically.
[object Object]
At this point Cut2D Proshould be being displayed and the dialog should be automatically populated with any licenses available on your account.
[object Object]
[object Object]
This page displays the selected license and module details. If you are changing current license details or adding a module a restart will be required for these to fully take effect. In this case a check box will appear allowing you to restart automatically. If this is checked then when you press Cut2D Pro will automatically be restarted to apply the license changes. If you do not select this option the license changes take effect the next time Cut2D Pro is restarted.
Manual Method
The manual method allows entry of license details without requiring an Internet connection. Selecting "Manual" and clicking will cause the manual entry form to be displayed.
[object Object]
The "Registered User Name" from your license information should be entered into the "Licensed To" area of the form and the license code can either be copied and pasted into the middle row of the dialog or manually typed into the lower section if "Enter license code manually" is selected. The button will become available when a code of the expected length has been entered.
If the product is already licensed then a module code can be entered at this stage instead of the product code. If you wish to manually activate both a product and module code the product code should be added here and there will be an opportunity to add the module code later. Pressing will set the license and display the summary screen.
[object Object]
