Job-Vorlagen
Job templates are files which can hold frequently used dimensions, machine settings, or geometry. They are like regular .crv3d or .crv files apart from a few important differences:
- When templates are opened, if you then decided to save them they will not overwrite the template, they will behave as though they are new files.
Creating a Job Template
To create a job template you will need to create a job like you usually would, with the required dimensions and machining setup. You can also add geometry that you want to form part of the template. Then click File > Save As Template and save the file in the desired location.
