Convert text to Curves
Converts selected text object into vector form, creating lines, arcs and Bezier spans that can be interactively edited. After conversion the text cannot be edited as a text object.
In most cases all the text created in Cut2D Pro can be VCarved, Engraved, Pocketed and Profile machined or used with the 3D modeling functions without converting to the curves.
In most cases all the text created in Cut2D Pro can be VCarved, Engraved, Pocketed and Profile machined without converting to the curves.
In most cases all the text created in Cut2D Pro can be Engraved, Pocketed and Profile machined without converting to the curves.
Some fonts do occasionally include loops and problems that need fixing using the Node Editing tools before it can be utilized for other functions.
