3D Design and Management
As well as creating toolpaths directly from 2D drawings, VCarve Pro can produce extremely flexible 3D toolpaths. These toolpaths are created from 3D design elements called 3D Components that can be generated from models created in external 3D design packages, imported as 3D clipart or built entirely from within VCarve Pro using 2D artwork as a source.
The 3D View
The Composite Model
VCarve Prohas been designed to work in a way which enables the user to easily create even very complex projects. In any situation, the best approach to producing something complicated is to break it down into smaller pieces until a level of simplicity is reached that can be understood and managed. In VCarve Prothis is achieved by letting the user work with pieces of the design which are combined to make the finished part. In the terminology of the software these pieces are called Components. To help organize the Components they are assigned to Levels. Step by step, Components and Levels can be created and modified until you have all the elements you need. In the images below you can see an example of how this might work. On the left you can see the separate component for a model of a bunch of grapes and on the right you can see these positioned to make the complete part - we call this resulting combination the Composite Model.
test
test
In VCarve Pro, the aim is to end up with a set of Components and Levels that when combined together will make the finished 3D part. One way to think of this is like building a 3D collage or assembly. As the design evolves, new Levels or shapes may need to be created or existing ones changed. The parts of the collage are managed with the Component Tree which will be covered in more detail later.
  1. Use a modeling tool to create shapes from 2D vectors.
  2. Import a pre-created 3d model - either a model previously created in Aspire or from another source such as a clipart library or a different modeling package.
  3. Create a 'texture' Component from a bitmap image.
  4. Use the Split Components Tool to break an existing Component into multiple pieces.
Dynamic Properties
Combine Modes
test
test
test
Note:
Add
test
test
Subtract
test
test
Merge
test
test
Low
test
test
Level Mirror Modes
  • Left to Right
  • Right to Left
  • Top to Bottom
  • Bottom to Top
  • Top Left Quadrant
  • Top Right Quadrant
  • Bottom Left Quadrant
  • Bottom Right Quadrant
Multi Sided View
