Draw Polygon
![](https://cdn.sanity.io/images/i7cqi3ri/10_5/49d3beb3ba2b6f704f8c06253f28e7619ee02937-243x400.png)
Interactive Creation
Quick Keys
Default
Example
Specifying Further Properties
Examples
Exact Size
Click to update the circle
Editing Existing Polygons
To edit an existing polygon select the polygon, edit the parameters and click to update the circle.
