3D Design and Management
The 3D View
The Composite Model
test
test
  1. Use a modelling tool to create shapes from 2D vectors.
  2. Import a pre-created 3D model - either a model previously created in Aspire or from another source such as a clipart library or a different modelling package.
  3. Create a 'texture' Component from a bitmap image.
  4. Use the Split Components Tool to break an existing Component into multiple pieces.
Dynamic Properties
Combine Modes
test
test
test
Note:
Add
test
test
Subtract
test
test
Merge
test
test
Low
test
test
Level Mirror Modes
  • Left to Right
  • Right to Left
  • Top to Bottom
  • Bottom to Top
  • Top Left Quadrant
  • Top Right Quadrant
  • Bottom Left Quadrant
  • Bottom Right Quadrant
Multi Sided View
