Slice Model
test
test
Model Slicing
Slice Thickness
Number of Slices
Example
Create Boundary Vectors
Slice Model
Close
Clicking will close the Slice Model form without completing the operation.
Slice Heights
There are two parts to the slice height control:
  • The height bar which gives a visual indication of the slice heights
  • The slice list which lists the slice heights using their z value
Controlling Slice Thickness
A specific slice height can be controlled by selecting it from the slice list, updating the value and clicking
Add New Slices
  • Entering a specifc z height for the slice and selecting apply; or
  • Double clicking on the height bar at a particular location
test
Double click to add slice
Removing Slices
3D View
  • Red areas show which are included in this slice
  • Green areas indicate that the component is above the slice height and so these will be sliced flat.
  • The slice will occur between the Red and the green areas.
test
Green areas are above the slice, red areas are the current slice.
  • Double clicking on the model will change the value of the active slice height to be equal to the clicked height.
  • Shift + Double Click will insert a new slice height at the clicked height.
  • Shift + Mousewheel up/down will raise/lower the actice slice height by a small amount allowing you to tweak the thickness to remove thin slices.
