Text On A Curve
Text Size
Maintain text Size
Scale text to fill curve
Text Spacing
Text Position
Above Curve
On Curve
Below Curve
Text on other side
Offset Distance
Text Alignment
Position on the curve
The text's position on the curve can be adjusted interactively, by dragging the anchor point handle in 2D View.
