Tool Database
The Tool Database can be accessed from the button through the various Toolpath forms. You can open the Toolpaths Tab button or through the Toolpaths menu.
Overview
  1. Tool geometry entities (organised hierarchically in the tree).
  2. List of Materials (Managed through the Material Management dialog).
  3. List of Machines (Managed through the Machine Management dialog).
  4. Cutting Data set for each tool geometry. This includes the Cutting Parameters, and Feeds & Speeds, and are defined per machine / material.
  1. Tool geometry: This is the physical properties of the tool such as the diameter, tip radius, etc...
  2. Cutting data: These include the Cutting Parameters and Feeds & Speeds of the tool. These values are defined for a particular material / machine.
Apply Changes
Tool Tree
New Tool
Copy Tool
  • Copied from the same tool, different material.
  • Tool with identical geometry, any material.
  • Created with default values.
Delete Tool
New Tool Group
Export Tools
Import Tools
A tool database file can be imported into the currently open tool database. You will have 3 options,
  1. Import: This will simply import the given tools under the selected group (or as a top-level tool / group).
  2. Merge: This will attempt to merge the incoming tool group hierarchy with the current one (without any regards for selection)
    1. Overwrite: When it's faced with two similarly nested tools that have the same tool geometry, the cutting data of the incoming tool will overwrite the current tool's cutting data for the active machine / material.
    2. Without overwriting: A new machine / material will be created to contain the cutting data of the incoming tools.
Tool Definition
Tool Type
test
V-Bit
test
Engraving
test
Tapered Ball Nose
test
Ball Nose
test
End Mill
test
Radiused End Mill
test
Form Cutters
test
Diamond Drag
test
Drills
Notes
To enter a link into the Note, go to the appropriate page in your Web Browser and select the URL of the page from the Address Bar.
CRTL+C to copy it and then in the Note Field, right click and use the "Paste" option to enter it into the Notes.
To use the HTML Link in the Note Window, hold the CRTL Key and click the link. This will open your computers default Web Browser and load the web page.
Diameter
Number of Flutes
Cutting Data
Creation / Copying
  1. Create with some default values which you can then change for your purposes.
  2. Copy from the same tool from a different material: This could be a sensible starting point if the materials have similar / close hardness.
  3. Copy from a different (identical) tool from the same (or different material)
Pass Depth
Stepover
Final Pass Stepover
Clearance Pass Stepover
Spindle Speed
Feed Rate
Plunge Rate
Material / Machine
Chip Load
Maximum Burn Rate
Tool Number
Per Machine
Material / Machine Management
Material
Machine
Online Tool Database
Download
Download the tool database stored on your portal account to replace your existing local tool database. This can be used for when we know there is a more up-to-date version online. You will also be prompted to update if that is the case.
Upload
Remote Tool Database
Using the Right most Icon you can load a Remote Tool Database from a URL link supplied to you. More on this in the Remote Tool Database page.
Using Form Cutters
test
Round-over
test
Ogee
test
Profile Cutting Strategy with Form cutter
Custom Form Cutters
Geometry
