Turn and Spin
![](https://cdn.sanity.io/images/i7cqi3ri/12/3238dbc45ebc09cf972aaecabf6583f9e476da69-238x403.png)
The Turn and Spin tool allows you to create a 3D component by turning or spinning a cross section (an open vector)
Turn
Turn takes a profile and turns (rotates) it around line from start point to end point to create a rounded symmetrical shape. To turn a shape select the vector cross section you want to turn and use the Turn (Rotate) option, this cross section should represent the silhouette of the shape you wish to create. You can click to create your 3D turned shape.
![](https://cdn.sanity.io/images/i7cqi3ri/12/daabafb4773cb892c4655b909eeb700ac3a42097-495x78.png)
![](https://cdn.sanity.io/images/i7cqi3ri/12/ef81cde74b5d61119ecc75484cd7045a14cff79a-497x143.png)
The profile to be turned can run beneath the line between the two end points
![](https://cdn.sanity.io/images/i7cqi3ri/12/24fd4fa306cb86dfb99187cb92ff9fa2adca8fad-883x150.png)
![](https://cdn.sanity.io/images/i7cqi3ri/12/96c372bbaab6eab468c7d8351c3904d1fd7d9148-526x124.png)
Spin
Spin takes a profile and spins it around the left end point of the cross section to create a circular component based on the profile shape of your cross section. To spin a shape select the vector cross section you want to spin around the left end point and click to create your 3D spun shape.
![](https://cdn.sanity.io/images/i7cqi3ri/12/85a5c3b07ea52c7e7e71cfc422e8f6d2cbe34940-425x95.png)
![](https://cdn.sanity.io/images/i7cqi3ri/12/532e09868703ef7ec64124117c1841d74e8379ab-358x307.png)
The Spin Tool will always Spin around the left end point, which may require you to move your vector to the right side of your job to accommodate the vector being spun to create the spun shape.
Scale to Exact Height
Checking ✓ this option scales the shape calculated so its maximum height is the value entered in the Height area of the form.
Common Modeling Options
![](https://cdn.sanity.io/images/i7cqi3ri/12/27da70074f188f52d0bf5ecbd65d4d0f3047b8cf-228x78.png)
Reset
Apply
Start New Component
Close
