Component Tree
Combine Modes
![test](https://cdn.sanity.io/images/i7cqi3ri/12/514a58c605eccfadc1bfddfc7c732a2222231751-132x132.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/9a81030b5dda793896120c6876040f310c63d55a-132x132.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/95234a00e3f9c315990ccbfe5639c110fc5f70ce-132x132.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/6dd0337cc5814294a099070e86a96ffb56768bc6-132x132.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/9328b8ff4b1cdd16a3f753855f4eec914df849d6-132x132.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/b4e96ff8d1b8fb5af398000992f4351cbc2f3595-132x132.png)
Organization
Component Levels.
Component Groups.
Selection
- By left-clicking on the component's name in the Component Tree
- By left-clicking on the associated grayscale component preview image in the 2D view
- By double left-clicking directly on the component in the 3D view
Selection in the 2D View
Selection in the 3D View
Because the left mouse button is used for twiddling the 3D view itself, a single left-click cannot be used for component selection directly. However, Aspire's 3D view supports most of the standard selection concepts described above, using double-clicks instead. Therefore, to select a component in the 3D view it must be double-clicked with the left mouse button. To select multiple components in the 3D view, hold down a Shift key and double-click each of the components you wish to add to the selection. To access the pop-up menu of commands associated with a component, double right-click it in the 3D View.
![](https://cdn.sanity.io/images/i7cqi3ri/12/dd50f336885e4185fe98627ed0f992f145f15225-295x190.png)
![](https://cdn.sanity.io/images/i7cqi3ri/12/f7835ab04a90826e08d11889e24ae73cf269289c-327x259.png)
Editing in the 3D View
Many of the dynamic component editing tools can now be accessed directly from the 3D View. Editing the components in the 3D View makes it quick and easy to see the immediate effect of the changes to the Composite Model. To access these editing options a component or components must first be selected. Once selected then either clicking the component again in the 3D view or clicking the Transform Mode icon (Move, Scale, Rotate Selection) will activate the 3D Transform Handles.
![](https://cdn.sanity.io/images/i7cqi3ri/12/a83f1b1fda7b48eed90805cf541c0a49ff5d3b14-934x728.png)
The majority of these will function in the same way that they do with objects in the 2D View.
There are also icons below that can be selected that will allow you to edit the component properties in the 3D view.
When selecting the additional settings option here you can adjust the Combine mode, Fade, Tilt and Appearance. When using the Fade and Tilt options in the 3D view you will need to set the direction of this in the 3D View instead.
![](https://cdn.sanity.io/images/i7cqi3ri/12/87ee083cb2341968a6283e8508ae52aaba2221d7-439x365.png)
