File
New
Creates a New Aspire job.
New from template...
Creates a new job based on existing Aspire job template
Open...
Opens an existing Aspire job
Close
Save
Saves the current Aspire file over the last saved version of the file.
Save As...
Save As Template...
Opens the standard File Save dialog so you can save the current file as a job template.
Increment and Save
Print
Print Preview
Print Setup
Import... ►
Export... ►
Export vectors from the job
Exit
Import
Import Vectors / Bitmaps...
Import Vector or Bitmap data.
Import 3D Model or Component
Export
Printing and Print Preview
