Manual Machine Configuration
If you have downloaded a machine configuration and would like to edit it, or you would just like to create a new machine then you can do so from Machine Configuration Dialog.
This will allow you to edit, duplicate, add or remove machines. It will allow you edit the post-processor associations for each configuration.
- Having a machine configuration allows you specifiy different feeds and speeds for your tools in the Tool Database.
- And then it will allow you to easily select a machine to save your toolpaths with later on.
