Advanced - Modelling 3D Rotary Projects
![](https://cdn.sanity.io/images/i7cqi3ri/12/64eb098a489215d2e4f03a354679bbf53ec94e0f-815x1105.png)
A simple way to start with 3D rotary models is to use add pieces of decorative clipart that is provided with Aspire. This process is very similar to adding clipart to single - or double - sided project, however there are some additional considerations that are specific to wrapped rotary machining.
To start, switch to the Clipart tab. Then choose a piece of clipart and drag and drop it into the workspace. Aspirewill show following message:
![](https://cdn.sanity.io/images/i7cqi3ri/12/a05514690301ef6c0ea2db93d743f259dca21300-872x194.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/320f7903a266dcc85566a2e833b0c612414cfdc1-1281x586.png)
As can be seen, the model contains only the selected decorative piece on the flat plane. Although the column is obviously a cylindrical solid, so far we only used 2D toolpaths to carve details on the surface of cylinder. So the fact that machined piece is a cylindrical solid, derives only from fact that the blank is a cylindrical solid itself. Aspireallows the 3D model to also describe a solid body.
In this example the intent is to only place a decorative piece on the surface, rather than define body of the column. Aspirecan see that we did not model a body and we are placing a piece of clipart, that is likely to be placed at the surface. By responding 'Yes' to the message we can confirm that it is our intent to use the component to decorate a surface.
More clipart can be placed as desired. Then the 3D view can be inspected. Once design is finished it is time to create toolpaths. In order to create 3D roughing toolpath, use the 3D Roughing Toolpath. Then create 3D finishing toolpath, using 3D Finish Toolpath. Select settings that are most appropriate for given application, while remembering which axis is rotating. The choice of axis may be particularly important if rotation axis speed is slower than linear axis.
Making a tapered column
![](https://cdn.sanity.io/images/i7cqi3ri/12/c71a707624984ca33e2c20eb3809e6698372e2d8-838x1038.png)
Double-click the zero plane component to open Component Properties. Enter 0.8 in the Base Height box. Select Tilt option. Click Set button in Tilt section, then switch to 2D view and then click in the middle left and then in the middle right. Set the angle to 3 degrees.
Since the modelling plane was adjusted for placing component on the surface, it needs to be adjusted again, so the component body is not 'inflated'. To do that open the Material Setup form. Adjust modelling plane by moving the slider down, until the Gap Inside Model is 0.
![](https://cdn.sanity.io/images/i7cqi3ri/12/7bd89ecd990fa7923701dfa6d4c78963e418bc3f-277x198.png)
After modelling a tapered shape, the 3D model of column will have a desired shape. However clipart pieces in the narrower parts have been distorted, as can be seen below. To fix that, one needs to stretch the components in the wrapped dimension, to compensate for distortion.
![test](https://cdn.sanity.io/images/i7cqi3ri/12/d4f4157fb30d416a58dbf62b9e1e926952aac31f-2166x661.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/70d5fb05a823a9214386a84d09e7b32b09e44895-2175x674.png)
![](https://cdn.sanity.io/images/i7cqi3ri/12/cf68dbf5bdbcb839b7e04ec36544b5b87adc4838-1448x1035.png)
Modelling turned shapes
![](https://cdn.sanity.io/images/i7cqi3ri/12/23efd12541ec551871b24961aa8eff38bca274a3-467x872.png)
Modelling turned shapes is quite easy. It requires a vector representing a profile of the desired shape and a Two Rail Sweep tool.
![](https://cdn.sanity.io/images/i7cqi3ri/12/f38d9e6cac02d72dc8df9012bd74ee5129b9f4e1-1820x553.png)
Select both of those rails and click the Use Selection button. The rails will then be highlighted. Then select the profile vector and click apply. Inspect the 3D view to verify the results.
Modelling cross section
![](https://cdn.sanity.io/images/i7cqi3ri/12/ce0835fba876229fdf1f6d38c2e5a523e1fa484b-985x956.png)
The Vector Unwrapper is useful when rather than modelling a profile along the rotation axis, it is more intuitive to specify a desired cross section. The tool transforms a vector, representing a cross section, into a profile vector that can be subsequently used with Two Rail Sweep tool.
When the shape is created, select it and open Vector Unwrapper. The tool will display a crosshair in place where the rotation axis is crossing the profile and a circle with the diameter of the material block. This will help you determine whether the shape with such cross profile will fit in current material block.
![](https://cdn.sanity.io/images/i7cqi3ri/12/7f999168195c7655a677f27d0494ff6057683144-1627x1088.png)
In this example, the Use Center of contour option was used. That means that rotation axis will be placed in the centre of vector's bounding box. One can also tick Simplify unwrapped vectors option to fit bezier curves, instead of using series of very short line segments. After apply is pressed, the unwrapped version of the selected cross section will be created, as have been shown below.
![](https://cdn.sanity.io/images/i7cqi3ri/12/e984b8057f43f38e1bb65d5083bd8b72d3e549c2-1627x925.png)
The tool automatically creates layer called 'Unwrapped Vectors Drive Rails' on which it places two blue line vectors on job sides, parallel to the rotation axis. In order to extrude the profile, open the Two Rail Sweep tool. Then select top and then bottom rail (left and right when Y axis is rotation axis) and confirm selection by clicking Use Selection button. The rails will now be highlighted. Now click on unwrapped vector and press apply. The 3D view will show a hexagonal column, that can be seen at the beginning of this section.
Modeling Plane
The Vector unwrapper is not restricted to simple shapes. In principle it is always possible to use convex shapes and certain concave shapes. The example below shows a heart profile unwrapped.
![test](https://cdn.sanity.io/images/i7cqi3ri/12/5be1581b74a1b471640d1cb3d38ea447aa937022-1627x1088.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/d11b2c1b471704ebd9eed1ed8b46189dd6d2887d-663x819.png)
![](https://cdn.sanity.io/images/i7cqi3ri/12/37722a87964ac9bb26dcf5ab0059d799c5af4f28-567x664.png)
![](https://cdn.sanity.io/images/i7cqi3ri/12/13b3e8074853ba4b0af77f589fff6dd234f5790f-1087x515.png)
![](https://cdn.sanity.io/images/i7cqi3ri/12/175967440e20519050925625cd57f7f2e8db9c5d-611x663.png)
