Interactive Selection Mode
Transform Handles
When in this mode the mouse is used to click on one of the handles which has appeared on the selected Vector/s. Each Transform handle is used for a specific editing operation as detailed here in the 2D View:
  • Middle - Move the vectors (Hold +Alt Move the selected objects in one axis)
  • Corner (White) - Scale the vectors proportionally (Hold +Alt Scaling non-proportionally, +Shift Scale around the centre)
  • Edges (White) - Scale the vector in one axis (Hold +Shift Scaling proportionally)
  • Corner (Black) - Rotate the vectors (Hold +Alt Rotate in 15° increments) about the Rotation Center.
To deselect objects,
  • Click the white background unless Shift is pressed.
  • Press Esc
  • Right click menu ► Unselect All
In the 3D View, the Transform Handles are:
  • Edges (Black) - Scale the vector in one axis (Hold +Shift Scaling proportionally)
  • Rotation Arrow (Top Black) - Rotate the vectors (Hold +Alt Rotate in 15° increments)
If you need an exact value for a Transformation, click into this box and type in the desired value, followed by Enter to accept the new value.
Usable In Both Views
2D View offers a more direct way to view your vectors while 3D Offers more flexability to work with Vectors in 3D Designs and to make use of the Edit Boxes.
