15. Advanced - Post-Processor Editing
G-Code Output
T1 M6
G17
G0 Z4.5000
G0 X0.0000 Y0.0000 S12000 M3
G0 X2.4567 Y7.8342 Z0.2500
G1 Z-0.0500 F5.0
HPGL Output
IN;PA;
PU2496,7960;
PD2496,7960;
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
PU2496,7960;
PU2496,6096;
Post Processor Sections
File Comments
+ History
+ Who When What
+ Tony 14/07/2006 Written
Global File Statements
Statement
Result
FILE_EXTENSION="txt"
UNITS="MM"
PRINT_DIRECT="YES"
RAPID_PLUNGE_TO_STARTZ="YES"
ROTARY_WRAP_Y=A
ROTARY_WRAP_X=B
INVERSE_TIME_MODE="YES"
Rotary: Enables / Disables output of the feedrate F in Inverse Time Feed Mode. In this mode, we're expected to complete a move in one divided by the F number of minutes.
In GCode, this would usually be a G93 to switch on Inverse Time Mode, or a G94 to set Units per Minutes mode.
LASER_SUPPORT = "YES"
Indicates that this post-processor supports laser toolpaths (if the Laser Module is installed).
MIN_ARC_RADIUS = 0.01
Optional minimum arc radius. Arcs which have a radius smaller than this value will be replaced with a single straight line move.
MAX_ARC_RADIUS = 1000.0
Optional maximum arc radius. Arcs which have a radius greater than this value will be polygonized.
POST_BASE
This is a no longer supported way of inheriting the content of another post-processor. See the POST_BASE Migration page for more details.
Tape Splitting Support
For example a command of:
would lead to...
Output will be split into multiple files of a maximum of 1000 lines (+ however many lines in there are within the footer section of the post processor), if a retract move exists after line 900 (1000 – 100), the file will be split at that move. If the file was called "toolpath" the split files would be named toolpath_1.tap, toolpath_2.tap etc. The first toolpath output will be "toolpath_ 1.tap" there will be no file named "toolpath" without an index number, (as INDEX_ON_FIRST_FILE=YES is used), unless the file was less than 1000 lines long, in which case the file would not be split.
Line Terminating Characters
LINE_ENDING="[13][12]"
Block Numbering
Statement
Result
LINE_NUMBER=0
LINE_NUMBER_INCREMENT=10
LINE_NUMBER_MAXIMUM=99999
Variables
Variable Name
Output using
Value
Example File
FEED_RATE
[F]
Current Feed Rate.
CUT_RATE
[FC]
Current Cut Feed Rate.
CNCShark-USB_Arcs_inch.pp
PLUNGE_RATE
[FP]
Current Plunge Feed Rate.
SPINDLE_SPEED
[S]
GCode_arc_inch.pp
POWER
[P]
grbl_mm.pp
TOOL_NUMBER
[T]
Current Tool Number.
PREVIOUS_TOOL_NUMBER
[TP]
Previous Tool Number.
NC-Easy.pp
LINE_NUMBER
[N]
Line Number.
TOOL_NAME
[TOOLNAME]
Name of Current Tool.
MaxNC_inch.pp
TOOL_NOTES
[TOOL_NOTES]
Busellato_Jet3006_arc_inch.pp
TOOLPATH_NAME
[TOOLPATH_NAME]
Name of Current Toolpath.
Viccam_ATC_Arcs_inch.pp
TOOLPATH_FILENAME
[TP_FILENAME]
ez-Router_inch.pp
TOOLPATH_DIR
[TP_DIR]
Woodp_arc_mm.pp
TOOLPATH_EXTENSION
[TP_EXT]
Toolpath File Extension.
TekcelE_Arc_ATC_3D.pp
TOOLPATH_PATHNAME
[PATHNAME]
Toolpath Folder Pathname.
WinPC-NC_ATC_Arcs_mm.pp
X_POSITION
[X]
GCode_arc_inch.pp
Y_POSITION
[Y]
GCode_arc_inch.pp
Z_POSITION
[Z]
GCode_arc_inch.pp
A_POSITION
[A]
ARC_CENTRE_I_INC_POSITION
[I]
ARC_CENTRE_J_INC_POSITION
[J]
ARC_CENTRE_I_ABS_POSITION
[IA]
Isel_arc_mm.pp
ARC_CENTRE_J_ABS_POSITION
[JA]
Isel_arc_mm.pp
ARC_START_X_POSITION
[ArcStartX]
TextOutput_Arcs_mm.pp
ARC_START_Y_POSITION
[ArcStartY]
ARC_MID_X_POSITION
[ArcMidX]
ARC_MID_Y_POSITION
[ArcMidY]
ARC_MID_X_INC_POSITION
[ArcMidXI]
ARC_MID_Y_INC_POSITION
[ArcMidYI]
ARC_RADIUS
[Radius]
The radius of an arc.
Bosch_ATC_Arcs_mm.pp
ARC_ANGLE
[Angle]
The angle of an arc.
Generic HPGL_Arcs.pp
X_HOME_POSITION
[XH]
CAMTech_CMC3_mm.pp
Y_HOME_POSITION
[YH]
CAMTech_CMC3_mm.pp
Z_HOME_POSITION
[ZH]
CAMTech_CMC3_mm.pp
SAFE_Z_HEIGHT
[SAFEZ]
EMC2 Arcs(inch)(*.ngc)
WRAP_DIAMETER
[WRAP_DIA]
X_LENGTH
[XLENGTH]
Length of material in X.
Y_LENGTH
[YLENGTH]
Length of material in Y.
Z_LENGTH
[ZLENGTH]
Length of material in Z.
X_MIN
[XMIN]
MaxNC_inch.pp
Y_MIN
[YMIN]
MaxNC_inch.pp
Z_MIN
[ZMIN]
MaxNC_inch.pp
X_MAX
[XMAX]
MaxNC_inch.pp
Y_MAX
[YMAX]
MaxNC_inch.pp
Z_MAX
[ZMAX]
MaxNC_inch.pp
X_ORIGIN_POS
[X_ORIGIN_POS]
Origin Position in X.
Y_ORIGIN_POS
[Y_ORIGIN_POS]
Origin Position in Y.
Z_ORIGIN
[Z_ORIGIN]
XY_ORIGIN
[XY_ORIGIN]
X, Y Origin.
TOOLS_USED
[TOOLS_USED]
TOOLPATHS_OUTPUT
[TOOLPATHS_OUTPUT]
TOOLPATH_NOTES
[TOOLPATH_NOTES]
FILE_NOTES
[FILE_NOTES]
File Notes (Edit > Notes).
TIME
[TIME]
File creation time.
DATE
[DATE]
File creation date.
DWELL_TIME
[DWELL]
Mach2_3_Arcs_inch.pp
PRODUCT
[PRODUCT]
TOOL_DIAMETER
[TDIA]
Tool diameter.
INVERSE_TIME
[FI]
Rotary: Current Inverse Time Rate
AvidCNC_WrapX2A_G93_inch.pp
Format of Variables
where
  • MX = Multiplier Value.
A typical variable
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
VAR
Z_HOME_POSITION
ZH
A
Z
F
1.0
-1
  2. Variable Name.
  3. Equals Sign.
Formatting the Output Value
Flag
Function
Default (without flag)
Left Justify the output
Values are right justified
0
Values is always output with a separator character ( in practice this would only change the output value if the value is set to output integer values only)
Default
Example
VAR LINE_NUMBER = [N|A||1.0]
VAR LINE_NUMBER = [N|A|N|1.0]
VAR FEED_RATE = [F|A||1.0]
VAR PLUNGE_RATE = [FP|A||1.0]
VAR CUT_RATE = [FC|A||1.0]
VAR X_POSITION = [X|A||1.0]
VAR Y_POSITION = [Y|A||1.0]
VAR Z_POSITION = [Z|A||1.0]
VAR X_POSITION = [X|A|X|1.3]
VAR X_POSITION = [X|A|X|1.4]
VAR X_MIN = [XMIN|A||1.3]
VAR Y_MIN = [YMIN|A||1.3]
VAR Z_MIN = [ZMIN|A||1.3]
VAR X_MAX = [XMAX|A||1.3]
VAR Y_MAX = [YMAX|A||1.3]
VAR Z_MAX = [ZMAX|A||1.3]
VAR X_MIN = [XMIN|A|X|1.3]
Multiplier Value
Post Processor Blocks
HEADER
begin HEADER
"Commands"
Home Position Information
  • Home X = [XH]
  • Home Y = [YH]
  • Home Z = [ZH]
  • Tool Number = [T]
  • Tool name = [TOOLNAME]
Initial cutting speeds
Spindle Speed
  • Spindle Speed = [S] R.P.M.
SPINDLE_ON
begin SPINDLE_ON
"Commands"
TOOLCHANGE
begin TOOLCHANGE
"Commands"
  • Previous Tool Number = [TP]
  • Tool Number = [T]
NEW_SEGMENT
begin NEW_SEGMENT
"Commands"
INITIAL_RAPID_MOVE
begin INITIAL_RAPID_MOVE
"Commands"
RAPID_MOVE
begin RAPID_MOVE
"Commands"
FIRST_FEED_MOVE
begin FIRST_FEED_MOVE
"Commands"
FEED_MOVE
begin FEED_MOVE
"Commands"
FIRST_CW_ARC_MOVE
begin FIRST_CW_ARC_MOVE
"Commands"
"Commands"
FIRST_CW_HELICAL_ARC_MOVE
"Commands"
CW_ARC_MOVE
begin CW_ARC_MOVE
"Commands"
CW_HELICAL_ARC_MOVE
begin CW_HELICAL_ARC_MOVE
"Commands"
FIRST_CCW_ARC_MOVE
begin FIRST_CCW_ARC_MOVE
"Commands"
"Commands"
"Commands"
CCW_ARC_MOVE
begin CCW_ARC_MOVE
"Commands"
begin CCW_HELICAL_ARC_MOVE
"Commands"
FOOTER
begin FOOTER
"Commands"
SPINDLE_ON
The Spindle On section is used after the Header and allows the Spindle on commands to be used in a combination Milling/Laser Post Processor.
If Spindle on commands are used in the Header, this Block should not be included.
begin SPINDLE_ON
"Commands"
  • M3 for Spindle On
  • [S] For Spindle Speed
Jet Support Sections
JET_TOOL_POWER
begin JET_TOOL_POWER
"Commands"
JET_TOOL_ON
begin JET_TOOL_ON
"Commands"
JET_TOOL_OFF
begin JET_TOOL_OFF
"Commands"
FEED_RATE_CHANGE
begin FEED_RATE_CHANGE
"Commands"
FIRST_PLUNGE_MOVE
begin FIRST_PLUNGE_MOVE
"Commands"
PLUNGE_MOVE
begin PLUNGE_MOVE
"Commands"
RETRACT_MOVE
begin RETRACT_MOVE
"Commands"
DWELL_MOVE
begin DWELL_MOVE
"Commands"
Special Characters
  • [10] Outputs a line feed.
For our example, we will add a tool-change section to this post processor. Go to the Machine Configuration option under the machine menu.
In the Associated Post Processor section, click on the (+) icon and scroll down the list to locate your Post Processor in the list.
Right click on it and select Customise
A new copy of the Post Processor will appear at the top of the list with a pen icon next to it.
Right click on this copy and select Open File Location
This will open the Windows folder with the .pp Post Processor file itself which you can then directly edit if you need to adjust commands to fit your particular machine setup. These .pp Post Processor files can be edited in any standard Text Editor software
To do this:
POST_NAME =
FILE_EXTENSION =
and alter these accordingly.
FILE_EXTENSION = "tap"
to make them read:
FILE_EXTENSION = "nc"
test
Tips And Tricks
