Set Size
![](https://cdn.sanity.io/images/i7cqi3ri/12/70eba16785cfc33b31c67a35b504daae5ab5c8f9-238x510.png)
Mode
There are two choice of scaling mode:
- Scale selection
- Scale items individually
If scale selection is chosen then the whole selection is scaled as if it were a single group. If scale items individually is chosen then the scaling is applied to each of them as they were all selected one by one.
Anchor
Link XY
Auto Scale Z
Interactive Sizing
The process is:
- Select the vectors
- Click a second time to activate the interactive options - handles on the selection box
- Click and drag on the white handles
