Job Setup - Single Sided
Job Type
Job Size
VCarve Desktop only supports job sizes up to a maximum of 25 inches square without tiling.
Z-Zero Position
XY Datum Position
Use Offset
Design Scaling
Modeling Resolution
Appearance
Clicking will pop up a dialog allowing you to set the color or material effect which will be applied to the base 3D model. It is possible to change this at any time and also to apply different colors and materials to different Components using the Component manager. See Preview Toolpaths to learn more about different material settings and adding custom material effects.
