License Dialog
Online Method
After logging in here with your V&Co account details another page may appear asking for permission for VCarve Desktop to access your license details.
This page will only appear if you have not already granted access. If this appears you should select "Allow" to enable VCarve Desktop to retrieve your license details automatically.
At this point VCarve Desktop should be being displayed and the dialog should be automatically populated with any licenses available on your account.
This page displays the selected license and module details. If you are changing current license details or adding a module a restart will be required for these to fully take effect. In this case a check box will appear allowing you to restart automatically. If this is checked then when you press VCarve Desktop will automatically be restarted to apply the license changes. If you do not select this option the license changes take effect the next time VCarve Desktop is restarted.
Manual Method
- Loading from a File
- Typing or Copying the values into the text fields
Load from File
- Double-click the file to open it with the software
- Go through the License Dialog wizard and click to Load the vlicence file.
Manual
License Data
Example License Data
Copying the License Code
Adding Module
