14. Advanced - Imported 3D Toolpath Files
Files from Vectric's Cut3D, PhotoVCarve and Design and Make Machinist that include 3D toolpaths can be imported into VCarve Pro using the main menu command: File ► Import ► PhotoVCarve, Machinist or Cut3D Toolpaths.
The 3D file must first be scaled to the required size before toolpaths are calculated, and then the complete file saved ready for importing into VCarve Pro. These files can only be moved and positioned inside VCarve Pro but cannot be scaled.
Positioning
![test](https://cdn.sanity.io/images/i7cqi3ri/12/08f9d02f13085d0f75bd2f9f9b10318da539a5ef-300x289.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/74d1197d1e8d41b1d3d2b145738434370d9635bb-300x289.png)
Toolpaths for the example above have been calculated with the X0 Y0 in the middle of the 3D design. When imported into VCarve Pro the data is automatically positioned using the same coordinates, which places three quarters of the design off the job. In the second image the grayscale image has been moved to the middle of the job.
![](https://cdn.sanity.io/images/i7cqi3ri/12/34de49c9e1d4e062758f8feea7febccdbe024a6e-234x350.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/8d6fd3cf80a28ce1373e2d14fb86675b9f9f38f4-300x231.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/2742f3704d70319d8ebd3ded81a66d709c028130-379x231.png)
Options
![](https://cdn.sanity.io/images/i7cqi3ri/12/83d2de7cec4bfefaf3c5ec617c0387c8d0bc1f08-249x425.png)
