Makerspace Initialization Dialog
The Makerspace Connection Setup wizard guides you through the process of connecting your software with a specific makerspace. This wizard is designed to run once during the initial setup of the software and ensures a seamless integration between the two systems.
Before running the Makerspace Connection Setup wizard, make sure you have the following information and resources available:
- Access credentials to your V&Co account
- Administrator access to the organization which owns the copy of VCarve Pro Makerspace Edition
- Network connectivity to establish a connections with the server.
Step 1: Authentication
- On the first page of the wizard click the "Login" button:
- Your default web browser will open, and you will be redirected to Vectric's login page
- Enter you account credentials (ensuring these are the same credential you used when purchasing the software)
- After successfully logging in, you will be redirected back to the wizard in the software
Step 2: Makerspace Selection
- The wizard will present you with a list of available makerspaces that can be connected to your software
- Select the desired makerspace from the list
- Press the 'Complete Setup' button to confirm the selection.
Step 3: Resolve "Too many machines are in use" Error
During the previous step, you may encounter an error message stating: "Too many machines are in use on this account. Please remove one to proceed." This error occurs when the maximum limit of 5 installations for VCarve Pro Makerspace edition has been reached. To proceed with the setup process, you need to revoke access for another device. Here's how:
- In the error message, click the 'Manage Devices' button.
- Your default web browser will open and redirect you to the V&Co website.
- On the V&Co website, you will be prompted to choose a device to revoke access from.
- Select the device that you no longer wish to have access to VCarve Pro Makerspace edition and confirm the revocation.
- Once access has been successfully revoked, you can close the web browser and return to the software.
- The setup process will automatically retry, and it should now complete successfully without the previous error.
