English
English
German
Italian
Japanese
French
Spanish
Quick Start Guides
Single Page
What's New
Keyboard Shortcuts
Vectric.com
Training Videos
Forum
Aspire Documentation
Design
Undo Operation
Quick Start Guides
Single Page
What's New
Keyboard Shortcuts
Vectric.com
Training Videos
Forum
Design
Move Selection
Join Open Vectors
Distort Object
Redo Operation
Text Selection
Circular Copy
Nest Parts
Trace Bitmap
Interactive Vector Trim
Edit Picture
Draw Star
Create Text
Undo Operation
Draw Arc
Interactive Selection Mode
Import Bitmap / Vectors
Snapping Options Dialog
Grouping and Ungrouping
Overlap Vectors
Group Selected Objects
Draw Ellipse
Object Selection Tools
Crop Bitmap
Set Size
Mirror
Draw Polygon
Offset Vectors
Copy Along Vectors
Vector Boundary
Fit Curves To Vectors
Vector Texture
Trim Objects
Rotate
Open a File
Draw Circle
Freehand Drawing
Create Fillets
Extend Vectors
Plate Production
Dimensions
Vector Selection Mode
Transform Mode
Draw Line
Node Editing Mode
Weld Vectors
Text On A Curve
Vector Validator
Vector Unwrapper
Measure - Inspect
Ungroup Selection
Array Copy
Subtract Vectors
Import Component / 3D Model
Convert text to Curves
Create a New File
Save a File
Alignment Tools
Draw Rectangle
Build Date: 10/22/2026, 5:02:38 AM
Undo Operation
