Set Size
Mode
There are two choice of scaling mode:
  • Scale selection
  • Scale items individually
If scale selection is chosen then the whole selection is scaled as if it were a single group. If scale items individually is chosen then the scaling is applied to each of them as they were all selected one by one.
Anchor
Link XY
Auto Scale Z
Interactive Sizing
The process is:
  • Select the vectors
  • Click a second time to activate the interactive options - handles on the selection box
  • Click and drag on the white handles
Usable In Both Views
