15. Advanced - Post-Processor Editing
G-Code Output
T1 M6
G17
G0 Z4.5000
G0 X0.0000 Y0.0000 S12000 M3
G0 X2.4567 Y7.8342 Z0.2500
G1 Z-0.0500 F5.0
HPGL Output
IN;PA;
PU2496,7960;
PD2496,7960;
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
PU2496,7960;
PU2496,6096;
Post Processor Sections
File Comments
+ History
+ Who When What
+ Tony 14/07/2006 Written
Global File Statements
Statement
Result
FILE_EXTENSION="txt"
UNITS="MM"
PRINT_DIRECT="YES"
RAPID_PLUNGE_TO_STARTZ="YES"
ROTARY_WRAP_Y=A
ROTARY_WRAP_X=B
INVERSE_TIME_MODE="YES"
Rotary: Enables / Disables output of the feedrate F in Inverse Time Feed Mode. In this mode, we're expected to complete a move in one divided by the F number of minutes.
In GCode, this would usually be a G93 to switch on Inverse Time Mode, or a G94 to set Units per Minutes mode.
LASER_SUPPORT = "YES"
Indicates that this post-processor supports laser toolpaths (if the Laser Module is installed).
MIN_ARC_RADIUS = 0.01
Optional minimum arc radius. Arcs which have a radius smaller than this value will be replaced with a single straight line move.
MAX_ARC_RADIUS = 1000.0
Optional maximum arc radius. Arcs which have a radius greater than this value will be polygonized.
POST_BASE
This is a no longer supported way of inheriting the content of another post-processor. See the POST_BASE Migration page for more details.
MAXIMUM_ROTATION
MAXIMUM_ROTATION = "90" This will limit the largest rotation possible in a rotary Axis. Larger turns will be broken down into multiple smaller turns. the largest value should be 179 while 90 is a reasonable safe choice.
MAXIMUM_LENGTH
MAXIMUM_LENGTH= "90" This will limit the largest straight movement possible to 90 units. This can be used to break up long moves into smaller sections which some controllers use to manage their feedrates.
RAPID_SPEED
Used to define a fixed Rapid speed to use when performing any Rapid moves which call for a Feedrate value
FIRST_TOOLPATH_NEW_SEGMENT = YES
When FIRST_TOOLPATH_NEW_SEGMENT = YES is specified the Post Processor will output TOOLCHANGE and NEW_SEGMENT immediately after the header for the first toolpath. This allows to avoid some code repetition between header and new segment
Normally the NEW_SEGMENT Code block is only called on the second or later toolpath in the event that the new segment uses a different Spindle Speed while using the same tool as the previous block. This can allow for condencing commands if the Header, TOOLCHANGE and NEW_SEGMENT contain many repeat commands.
Tape Splitting Support
For example a command of:
would lead to...
Output will be split into multiple files of a maximum of 1000 lines (+ however many lines in there are within the footer section of the post processor), if a retract move exists after line 900 (1000 – 100), the file will be split at that move. If the file was called "toolpath" the split files would be named toolpath_1.tap, toolpath_2.tap etc. The first toolpath output will be "toolpath_ 1.tap" there will be no file named "toolpath" without an index number, (as INDEX_ON_FIRST_FILE=YES is used), unless the file was less than 1000 lines long, in which case the file would not be split.
Line Terminating Characters
LINE_ENDING="[13][12]"
Block Numbering
Statement
Result
LINE_NUMBER_START=0
LINE_NUMBER_INCREMENT=10
LINE_NUMBER_MAXIMUM=99999
Variables
Variable Name
Output using
Value
Example File
FEED_RATE
[F]
Current Feed Rate.
CUT_RATE
[FC]
Current Cut Feed Rate.
CNCShark-USB_Arcs_inch.pp
PLUNGE_RATE
[FP]
Current Plunge Feed Rate.
SPINDLE_SPEED
[S]
GCode_arc_inch.pp
POWER
[P]
grbl_mm.pp
TOOL_NUMBER
[T]
Current Tool Number.
PREVIOUS_TOOL_NUMBER
[TP]
Previous Tool Number.
NC-Easy.pp
LINE_NUMBER
[N]
Line Number.
TOOL_NAME
[TOOLNAME]
Name of Current Tool.
MaxNC_inch.pp
TOOL_NOTES
[TOOL_NOTES]
Busellato_Jet3006_arc_inch.pp
TOOLPATH_NAME
[TOOLPATH_NAME]
Name of Current Toolpath.
Viccam_ATC_Arcs_inch.pp
TOOLPATH_FILENAME
[TP_FILENAME]
ez-Router_inch.pp
TOOLPATH_DIR
[TP_DIR]
Woodp_arc_mm.pp
TOOLPATH_EXTENSION
[TP_EXT]
Toolpath File Extension.
TekcelE_Arc_ATC_3D.pp
TOOLPATH_PATHNAME
[PATHNAME]
Toolpath Folder Pathname.
WinPC-NC_ATC_Arcs_mm.pp
X_POSITION
[X]
GCode_arc_inch.pp
Y_POSITION
[Y]
GCode_arc_inch.pp
Z_POSITION
[Z]
GCode_arc_inch.pp
A_POSITION
[A]
ARC_CENTRE_I_INC_POSITION
[I]
ARC_CENTRE_J_INC_POSITION
[J]
ARC_CENTRE_I_ABS_POSITION
[IA]
Isel_arc_mm.pp
ARC_CENTRE_J_ABS_POSITION
[JA]
Isel_arc_mm.pp
ARC_START_X_POSITION
[ArcStartX]
TextOutput_Arcs_mm.pp
ARC_START_Y_POSITION
[ArcStartY]
ARC_MID_X_POSITION
[ArcMidX]
ARC_MID_Y_POSITION
[ArcMidY]
ARC_MID_X_INC_POSITION
[ArcMidXI]
ARC_MID_Y_INC_POSITION
[ArcMidYI]
ARC_RADIUS
[Radius]
The radius of an arc.
Bosch_ATC_Arcs_mm.pp
ARC_ANGLE
[Angle]
The angle of an arc.
Generic HPGL_Arcs.pp
X_HOME_POSITION
[XH]
CAMTech_CMC3_mm.pp
Y_HOME_POSITION
[YH]
CAMTech_CMC3_mm.pp
Z_HOME_POSITION
[ZH]
CAMTech_CMC3_mm.pp
SAFE_Z_HEIGHT
[SAFEZ]
EMC2 Arcs(inch)(*.ngc)
WRAP_DIAMETER
[WRAP_DIA]
X_LENGTH
[XLENGTH]
Length of material in X.
Y_LENGTH
[YLENGTH]
Length of material in Y.
Z_LENGTH
[ZLENGTH]
Length of material in Z.
X_MIN
[XMIN]
MaxNC_inch.pp
Y_MIN
[YMIN]
MaxNC_inch.pp
Z_MIN
[ZMIN]
MaxNC_inch.pp
X_MAX
[XMAX]
MaxNC_inch.pp
Y_MAX
[YMAX]
MaxNC_inch.pp
Z_MAX
[ZMAX]
MaxNC_inch.pp
X_ORIGIN_POS
[X_ORIGIN_POS]
Origin Position in X.
Y_ORIGIN_POS
[Y_ORIGIN_POS]
Origin Position in Y.
Z_ORIGIN
[Z_ORIGIN]
XY_ORIGIN
[XY_ORIGIN]
X, Y Origin.
TOOLS_USED
[TOOLS_USED]
TOOLPATHS_OUTPUT
[TOOLPATHS_OUTPUT]
TOOLPATH_NOTES
[TOOLPATH_NOTES]
FILE_NOTES
[FILE_NOTES]
File Notes (Edit > Notes).
TIME
[TIME]
File creation time.
DATE
[DATE]
File creation date.
DWELL_TIME
[DWELL]
Mach2_3_Arcs_inch.pp
PRODUCT
[PRODUCT]
TOOL_DIAMETER
[TDIA]
Tool diameter.
INVERSE_TIME
[FI]
Rotary: Current Inverse Time Rate
AvidCNC_WrapX2A_G93_inch.pp
Format of Variables
where
  • MX = Multiplier Value.
A typical variable
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
VAR
Z_HOME_POSITION
ZH
A
Z
F
1.0
-1
  2. Variable Name.
  3. Equals Sign.
Formatting the Output Value
Flag
Function
Default (without flag)
Left Justify the output
Values are right justified
0
Values is always output with a separator character ( in practice this would only change the output value if the value is set to output integer values only)
Default
Example
VAR LINE_NUMBER = [N|A||1.0]
VAR LINE_NUMBER = [N|A|N|1.0]
VAR FEED_RATE = [F|A||1.0]
VAR PLUNGE_RATE = [FP|A||1.0]
VAR CUT_RATE = [FC|A||1.0]
VAR X_POSITION = [X|A||1.0]
VAR Y_POSITION = [Y|A||1.0]
VAR Z_POSITION = [Z|A||1.0]
VAR X_POSITION = [X|A|X|1.3]
VAR X_POSITION = [X|A|X|1.4]
VAR X_MIN = [XMIN|A||1.3]
VAR Y_MIN = [YMIN|A||1.3]
VAR Z_MIN = [ZMIN|A||1.3]
VAR X_MAX = [XMAX|A||1.3]
VAR Y_MAX = [YMAX|A||1.3]
VAR Z_MAX = [ZMAX|A||1.3]
VAR X_MIN = [XMIN|A|X|1.3]
Multiplier Value
Post Processor Blocks
HEADER
begin HEADER
"Commands"
Home Position Information
  • Home X = [XH]
  • Home Y = [YH]
  • Home Z = [ZH]
  • Tool Number = [T]
  • Tool name = [TOOLNAME]
Initial cutting speeds
Spindle Speed
  • Spindle Speed = [S] R.P.M.
SPINDLE_ON
begin SPINDLE_ON
"Commands"
TOOLCHANGE
begin TOOLCHANGE
"Commands"
  • Previous Tool Number = [TP]
  • Tool Number = [T]
NEW_SEGMENT
begin NEW_SEGMENT
"Commands"
INITIAL_RAPID_MOVE
begin INITIAL_RAPID_MOVE
"Commands"
This Block is Disabled when Keep out zones are enabled in a Project.
Refer to STRAIGHT_RAPID_MOVE below.
RAPID_MOVE
begin RAPID_MOVE
"Commands"
FIRST_FEED_MOVE
begin FIRST_FEED_MOVE
"Commands"
FEED_MOVE
begin FEED_MOVE
"Commands"
FIRST_CW_ARC_MOVE
begin FIRST_CW_ARC_MOVE
"Commands"
"Commands"
FIRST_CW_HELICAL_ARC_MOVE
"Commands"
CW_ARC_MOVE
begin CW_ARC_MOVE
"Commands"
CW_HELICAL_ARC_MOVE
begin CW_HELICAL_ARC_MOVE
"Commands"
FIRST_CCW_ARC_MOVE
begin FIRST_CCW_ARC_MOVE
"Commands"
"Commands"
"Commands"
CCW_ARC_MOVE
begin CCW_ARC_MOVE
"Commands"
begin CCW_HELICAL_ARC_MOVE
"Commands"
FOOTER
begin FOOTER
"Commands"
SPINDLE_ON
The Spindle On section is used after the Header and allows the Spindle on commands to be used in a combination Milling/Laser Post Processor.
If Spindle on commands are used in the Header, this Block should not be included.
begin SPINDLE_ON
"Commands"
  • M3 for Spindle On
  • [S] For Spindle Speed
Jet Support Sections
JET_TOOL_POWER
begin JET_TOOL_POWER
"Commands"
JET_TOOL_ON
begin JET_TOOL_ON
"Commands"
JET_TOOL_OFF
begin JET_TOOL_OFF
"Commands"
Drill Banks
These sections are for supporting drill banks.
A drill bank is a tool that has multiple individual drills arranged on horizontal and vertical arms. These can be engaged (extended) or disengaged (retracted) individually prior to plunging, to facilitate efficient drilling of hole arrays.
The CAM software can output drill bank instructions in one of two modes:
  • Pattern-based mode (for controllers that accept a bitmask or combined drill selection command)
  • Per-drill mode (for controllers that accept individual drill commands)
The two modes are mutually exclusive, and each make use of different sections. As such, the set of sections defined in the post processor determines the mode of output. Both use SETUP_DRILL_BANK and FINAL_DRILL_BANK_ACTION, but pattern-based mode uses only DRILL_BANK_PATTERN, whilst per-drill mode uses only DRILL_BANK_EXTEND_DRILL and DRILL_BANK_RETRACT_DRILL. Failure to define SETUP_DRILL_BANK and FINAL_DRILL_BANK_ACTION, or defining an invalid combination of DRILL_BANK_PATTERN, DRILL_BANK_EXTEND_DRILL, and DRILL_BANK_RETRACT_DRILL will prohibit the saving of drill bank toolpaths.
SETUP_DRILL_BANK
+ Commands output when entering drill bank mode
begin SETUP_DRILL_BANK
"Commands"
For an example of a SETUP_DRILL_BANK section, see the file: Weinig_OSAI_DB_mm.pp
Commands that are output at the start of every block of drill bank moves. This can be at the very start of the output if the first toolpath uses a drill bank.
DRILL_BANK_PATTERN
+ Commands output on pattern change
begin DRILL_BANK_PATTERN
"Commands"
For an example of a DRILL_BANK_PATTERN section, see the file: Weinig_OSAI_DB_mm.pp
Commands that are output on pattern change (pattern-based mode only).
+ Commands output on drill extend
begin DRILL_BANK_EXTEND_DRILL
"Commands"
For an example of a DRILL_BANK_EXTEND_DRILL section, see the file: SERON_OSAI_helisa_DB_mm.pp
Commands that are output on drill extend (per-drill mode only).
+ Commands output on drill retract
begin DRILL_BANK_RETRACT_DRILL
"Commands"
For an example of a DRILL_BANK_RETRACT_DRILL section, see the file: SERON_OSAI_helisa_DB_mm.pp
Commands that are output on drill retract (per-drill mode only).
DRILL_BANK_FINAL_ACTION
+ Commands output when exiting drill bank mode
begin FINAL_DRILL_BANK_ACTION
"Commands"
For an example of a FINAL_DRILL_BANK_ACTION section, see the file: Weinig_OSAI_DB_mm.pp
Commands that are output at the end of every block of drill bank moves.
Variables
Variables Available:
Var Name
Output Using
Value
DRILL
[DB]
Bitwise OR of user_drill_number for all engaged drills
DRILL_X
[DBX]
Bitwise OR for horizontal-only drills
DRILL_Y
[DBY]
Bitwise OR for vertical-only drills
DRILL_LIST
[DL]
Formatted Drill List
DRILL_LIST Variable
The DRILL_LIST variable is often required if the controller requires a specific formatting for output rather than just a binary representation of engage drills.
The format for the DRILL_LIST variable is:
var DRILL_LIST = [short_name|prefix|separator|first_separtor]
where
  • prefix: Text before each drill number
  • separator: Text between subsequent drills
  • first_separator: Text between first and second drill
For example, if drills 1, 3, 5 are engaged with the format [DL|D|,| ]. The the output is:
D1 D3,D5 (space after first, commas after rest)
Additional Variables
Var Name
Output Using
Value
CURRENT_DRILL
[CD]
The single drill number being extended or retracted.
Cutter Compensation
Cutter compensation (cutter comp) tells the CNC controller to offset the toolpath left or right by the tool radius, it can be used to adjust for any difference in radius between the tool the software was programmed with and the actual tool to be used, often employed to account for tool wear.
Cutter comp is an optional feature tied to profile toolpaths and only available with the Advanced Machining Module. When enabled, the post-processor embeds compensation commands into the lead move output lines, rather than outputting them as separate sections.
Cutter compensation uses an **inline string variable** approach to adjusting output:
  1. Three paragraphs define what to output for left/right/off
  2. At output time, the appropriate paragraph is rendered into a string variable (CUTTER_COMP`)
  3. That variable is referenced inline in lead move output lines (e.g., FEED_MOVE, FIRST_FEED_MOVE, CCW_ARC_MOVE)
  4. After the lead move is output, the variable is cleared back to empty
So in order to use Cutter Compensation you must define three sections:
begin CUTTER_COMP_LEFT
begin CUTTER_COMP_RIGHT
begin CUTTER_COMP_OFF
Example
"G41"
"G42"
"G40"
"[CUTTER_COMP]G1[X][Y][Z][F]"
begin FEED_MOVE
"[CUTTER_COMP]G0[X][Y][Z]"
The above example would give the following output for a profile toolpath with left cutter compensation enabled:
G0 X0.000 Y0.000 Z30.000 ← rapid to start (no comp yet, [CUTTER_COMP] is "")
G1 X0.000 Y0.000 Z-5.000 F500.0 ← plunge
G41 G1 X10.000 Y0.000 Z-5.000 F1000.0 ← first feed move with comp LEFT
G1 X20.000 Y0.000 Z-5.000 F1000.0 ← subsequent moves (comp unchanged, variable is "")
G1 X20.000 Y10.000 Z-5.000 F1000.0
G1 X10.000 Y10.000 Z-5.000 F1000.0
G40 G1 X0.000 Y.000, Z-5.000 F1000.0 ← comp OFF at end of profile
G0 X0.000 Y0.000 Z30.000 ← retract (no comp, variable is "")
FEED_RATE_CHANGE
begin FEED_RATE_CHANGE
"Commands"
FIRST_PLUNGE_MOVE
begin FIRST_PLUNGE_MOVE
"Commands"
PLUNGE_MOVE
begin PLUNGE_MOVE
"Commands"
RETRACT_MOVE
begin RETRACT_MOVE
"Commands"
DWELL_MOVE
begin DWELL_MOVE
"Commands"
INITIAL_STRAIGHT_RAPID_MOVE
begin INITIAL_STRAIGHT_RAPID_MOVE
"Commands"
Used to define initial commands when outputting a Keepout Zone Rapid move. This can be used to replace the standard RAPID_MOVE command to use G1 with a given rapid feedrate instead of a G0 move when the machine does not interpolate is G0 commands.
FIRST_STRAIGHT_RAPID_MOVE
begin FIRST_STRAIGHT_RAPID_MOVE
"Commands"
  • G00 [XH] [YH] [ZH] Rapid to the next X,Y,Z position.
  • F400 An example of a fixed Feedrate to use for the first in a series of Rapid moves.
Used to define the first Rapid commands when outputting a Keepout Zone Rapid move. This can be used to apply additional commands in addition to the typical G0 XYZ commands, such as a fixed feedrate to use for this move.
This variable is only needed if the the first rapid move requires an additional command which can't be included in every standard STRAIGHT_RAPID_MOVE
STRAIGHT_RAPID_MOVE
begin STRAIGHT_RAPID_MOVE
"Commands"
Used to define commands when outputting a Keepout Zone Rapid move. This can be used to replace the standard RAPID_MOVE command to use G1 with a given rapid feedrate instead of a G0 move when the machine does not interpolate is G0 commands.
Special Characters
  • [10] Outputs a line feed.
For our example, we will add a tool-change section to this post processor. Go to the Machine Configuration option under the machine menu.
In the Associated Post Processor section, click on the (+) icon and scroll down the list to locate your Post Processor in the list.
Right click on it and select Customise
A new copy of the Post Processor will appear at the top of the list with a pen icon next to it.
Right click on this copy and select Open File Location
This will open the Windows folder with the .pp Post Processor file itself which you can then directly edit if you need to adjust commands to fit your particular machine setup. These .pp Post Processor files can be edited in any standard Text Editor software
To do this:
POST_NAME =
FILE_EXTENSION =
and alter these accordingly.
FILE_EXTENSION = "tap"
to make them read:
FILE_EXTENSION = "nc"
Tips And Tricks
Post Processor Naming Conventions
Within the post processors that ship with the products you will see the following terms or abbreviations used:
  • Arc or Arcs = The post processor will output true arcs within the design as Arc moves, (G2,G3,Radius of Arc etc.).
  • Inc = Arcs are output with centre coordinates incremental to the last move.
  • Abs = Arcs are output with absolute coordinate values.
  • ATC = The post processor will output Automatic Tool Change (ATC) commands.
  • WY = Wrapped out output post processor – Y values wrapped around X axis
  • WX = Wrapped out output post processor – X values wrapped around Y axis
  • TSnumber = Tape Splitting post processor.
  • An optional number is the maximum number of lines that will be output within a single file. Files that exceed this number of lines will be split into multiple files. (See Tape Splitting Support for more details).
  • (mm) = The post processor units are Metric.
  • (inch) = The post processor units are English (Imperial) inches.
  • (*.xyz) = The file extension that the output file will be created with.
