Advanced - Importing External Models in a Rotary Project
Importing Full-3D models
Overview
  1. Setting-up rotary project
  2. Choosing file for import
  3. Orientating the model in material block
  4. Scaling the model
  5. Finishing the import
Setting up a rotary project
To start the importing process, use Import a Component or 3D Model tool from the Modelling tab
test
test
The same model imported without distortion
test
3-axis rotary machining, tool correctly positioned
test
3-axis rotary machining, tool side is touching the stock
Scaling imported model
Finishing import
Importing Flat Models
