Laser Fill Toolpath
The Laser Fill toolpath drives a laser along or inside your vectors. It hatches the area inside closed vectors to engrave a solid region.
Tool and Power
Tool Selection
Fill Options
Stepover
The spacing between the hatch lines that fill the area.
Hatch Angle
The angle of the fill lines.
Strategy
Whether to fill everything together, or region by region.
Cross Hatch
Adds a second set of fill lines at right angles to the first.
Outline
Adds an outline pass around the filled area.
Vectors to Machine
Vectors can be selected for machining in one of two ways:
  • Manually using the selection tool.
  • Automatically by choosing a layer from the dropdown menu
If you choose to use the automatic selection then all of the vectors on the chosen layer are machined at the point of toolpath calculation.
The automatic selection works at the point of calculation. If you add or remove vectors from a layer you need to recalculate the toolpaths.
