Version 1.0.6
  • Custom image textures — You can now apply your own image as a material texture, giving you more control over how your job previews look.
  • Show Application Data Folder — A new item in the Help menu opens the folder where the application stores its data, making it much easier to locate settings and log files when you need them.
  • Translated menus on Mac — The Window and application menus on macOS now appear in your chosen language.
  • Offset tool improvements — General improvements to the behaviour and reliability of the Offset tool.
  • Clearer size limit messages — Error messages about oversized material or artwork now tell you what the maximum allowed dimension actually is.
  • Formulas preserved after calculating toolpaths — Formulas entered into toolpath fields are no longer lost once the toolpath has been calculated.
  • Spell checking on long text — Fixed an issue where accepting a spelling correction in a long block of text could replace the wrong characters.
  • First save no longer reports an error — Fixed the error message that could appear the first time a new file was saved.
  • Long filenames — The disclosure triangle next to the filename is no longer pushed out of view when the name is very long.
  • Fillet tool — The edit field now stays anchored at the fillet point while you work, rather than moving unexpectedly.
  • Text editing — Snapping is now disabled while editing text, and the typing cursor only appears when hovering over text that's actually selected.
  • Smoother polylines — Fixed two issues with smooth-mode polylines: an incorrect preview when closing a curve back at its start point, and curves not closing properly when switching to smooth mode just before the final segment.
  • Cancelling operations — Stopping a long-running operation now interrupts work already in progress instead of waiting for it to finish.
  • Stability when recalculating toolpaths — Fixed a crash that could occur when toolpaths were recalculated.
  • Stability when closing files — Fixed a crash that could happen if you closed an unmodified file from the menu while the filename popup was open.
  • Stability in the material setup dialog — Fixed a crash when closing the tool database material dialog.
  • No more freezing when resizing windows — Fixed a hang that could occur while resizing certain dialogs and panels.
  • Improved 3D and simulation view rendering — Corrections to how the 3D and simulation views decide what to draw, for more consistent display.
  • Better problem reporting — If the application ever becomes unresponsive, the report we receive now points to the genuine cause, helping us fix such issues faster.
