Interactive Selection Mode
When in this mode the mouse is used to click on one of the handles which has appeared on the selected Vector/s. Each handle is used for a specific editing operation as detailed here:
  • Middle - Move the vectors (Or +Alt Move the selected objects in one axis)
  • Corner (White) - Scale the vectors proportionally (Or +Alt Scaling non-proportionally, +Shift Scale around the centre)
  • Edges (White) - Scale the vector in one axis (Or +Shift Scaling proportionally)
  • Corner (Black) - Rotate the vectors (Or +Alt Rotate in 15° increments)
To deselect objects,
  • Click the white background unless Shift is pressed.
  • Press Esc
  • Right click menu ► Unselect All
