Release Notes : 10.5
10.515
Fix crash previewing empty toolpaths
Fix rare crash when snapping
Fix issue skipping flat regions in Moulding Toolpath
Fix Laser toolpath using feed rate and not rapid rate with laser off
Fix Vector Validator issue
Fix Chamfering self-intersection issue
Fix Toolpath Merging sometimes breaking when a toolpath contains tabs
Fix 3D Roughing leaving a seam
Fix issue showing the job dimension in the drawing tab
Fix issue with Nesting and part detection of inner vectors
Fix issue importing files when a drawing tool is open
10.514
Fix crash in Pocketing Toolpath when open vectors are selected (regression in 10.513)
Added confirmation when clicking 'Cancel' button in Tool Database
10.513
Fix various crashes
Fix issue with toolpath merging
Fix diamond drag tool line width issue
Fix simulation model disappearance issue
Fix SVG import issue handling quadratic beziers
Fix Thread Milling not reflecting material setup safe gaps changes
Update size in Set Size form when node editing
Remember and display Pocketing toolpath options correctly
Fix Job Sheet creation failure with extended characters
Fix gouge in pocketing toolpath
Fix pocketing toolpath issue ignoring start depth sometimes.
10.512
Fix SVG import in some cases using groups in <defs>
and <use>
File Dialog: Fix issue with file dialog appearing multiple times
3D Model Import: Fixed bug with 3D model import when zero plane is at bottom of model
Reflect change to Plunge (Z2) in the 3D View of the toolpath.
Pocket Toolpath: Fix slot cutting cut depth.
Pocket Toolpath: Fixed crash when pocketing toolpath defaults are corrupted
Pocket Toolpath: Fixed bug where invalid pocketing toolpath was being created via the LUA CreatePocketingToolpath() command
Pocket Tooolpath: Fixed issue with naming of duplicate pocket toolpaths
Moulding Toolpath: Fix incorrect error in some cases with variable stepover.
Laser Picture Toolpath: Fix issue rastering outside cropped bitmap
V-Transfer: Fix spindle speed override controls.
Fix various crashes.
10.509
Fixed character encoding in Setup Sheet gadget
Fixed issue when nesting more than 999 parts
Add / Update post-processors for Masso CanCam
, BRAVOPRODIGY
and ShopSabre
Fix oversized components created from bitmaps
Fix some gouge issues in V-Carving strategy
Fix Pocketing toolpath issues in some cases when using tapered Ball Nose
Fix ramping issue in Moulding Toolpath
Fix issue with Moulding Toolpath depth pass.
Fix Tiling toolpath issue gouging between tiles
Fix Laser toolpath support in Job Sheet
Fix Laser Cut & Fill output on multi-pass toolpaths when projecting over a model.
Handling extreme Laser Kerf values
Fix renaming Laser toolpath creating a new toolpath
Fixed various crashes.
10.507
Fixed issue with software sometimes hanging when file dialog was displayed.
Fixed issue with post-processor name not displaying if it contained diactric marks.
Fixed issue with power variable being output for non-laser tools.
Fixed issue with power variable stuck at 0.
Give more space to the toolpath tree when the Save Toolpath dialog is open.
Fix invalid project status where couldn't add Toolpaths.
10.506
Fix crash when creating toolpath group.
Fix crash when using Trim Objects tool with refitting option.
Fix issue with help page not showing for Pocketing Toolpath.
Fix crash during two-sided nesting.
Fixed crash during vector unwrapping.
Fixed crash with 0 length tabs.
Fixed issue with editing moulding toolpath template.
Fixed cut through warning sometimes displaying unecessarily.
Fix Windows XP compatibility issue
Add missing visual indicator when snapping to some intersections.
10.505
Fixed issue with TP_DIR
post-processor variable showing the temporary path.
Fixed issue with tape splitting not copying extra toolpath files
Fix toolpath template handling of missing layers
Updated VTransfer to V2.11
Fix Vector Texture tool crashes and slowdown
Fix Tabs on Leads causing file issues.
Fix crash in laser picture toolpath
10.504
Fix 3D view zoom to selected component
Fix Grbl post-processor issues (ramp issue and missing feed rate)
Fix Array Copy toolpath editing
Fix profile toolpath cut depth check
10.503
Fixed issue with start being added twice in the Pocketing Toolpath
Fixed crash during Chamfer Toolpath calculation
Fix default tool selection for Thread Milling and Laser Engraving strategies.
If an error occurs during post-processing, don't output anything to the file.
Add back CNCShark
and CNCPiranha
post-processors as aliases for the new Next_Wave_CNC
10.502
See the 10.5 What's New page and videos
