Creating a Rotary Job
Z Origin
Tip:
XY Origin
![](https://cdn.sanity.io/images/i7cqi3ri/11/f0d9d017af1336ad58ae3830b5cb06b501d3cacd-221x96.png)
Orientation
![](https://cdn.sanity.io/images/i7cqi3ri/11/13dd064315aecc17ab2360a6695714a4b5c80a69-221x96.png)
Vector Layout
Choosing stock material
![](https://cdn.sanity.io/images/i7cqi3ri/11/fa6ac5402221de43ef50be70f9d2a54a73df2b25-600x300.png)
