Edit Sheet - Double Sided
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/a3a77b1c3b5e0d3fd8fc91b6c2a611973b2a4cea-243x623.png)
Job Type
Job Size
Z Zero Position
Zero off same side
XY Datum Position
Use Offset
Flip Direction Between Sides
Design Scaling
