Edit Sheet - Single Sided
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/77e8cc50292b6b3c16cc9ca1b074cc48f6ad9cab-243x548.png)
The size forms may be limited
Job Type
Job Size
Z-Zero Position
XY Datum Position
Use Offset
Design Scaling
