Vector Boundary
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/6a5ef6b6d6b02d64408992783016ae8729d997a4-243x278.png)
Offset Boundary
Rubber Band Boundary
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/9655074d7fdcd02dadcfe6fc5b8799c147927354-191x121.png)
Offset Boundary only
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/6b44a403b24ad6dbec7638449e77b4b3d95d3141-191x121.png)
Offset Boundary and Rubber Band together
