Create Fillets
Fillets or radiuses can be added interactively at points where any two spans on a contour meet.
Creating Fillets
To use the filleting tool we select the icon from the drawing tab. Choose a radius for the fillet and the type of fillet you would like to use.
When the mouse cursor is near a node that can be filletted, the mouse cursor changes to show a check-mark ✓:
When in the 3D View, the software will in addition show you a preview of the fillet it will created before you click to confirm the creation of the fillet.
When the mouse is hovering over the fillet point, before clicking, you can also type in a new value to use as the radius of the fillet, and then press Enter to confirm the value before then clicking to create that fillet.
Fillet Type
Normal Fillet
This creates a standard corner fillet based on the Radius defined, typically this would be used for design purposes and not for editing a slot for fitting purposes. Below left the image shows the vector before filleting the two inside radii, on the right is the filleted version
test
Straight Line Span Vectors before Filleting
test
Straight Line Span Vectors After Filleting
Dog-Bone Fillet
This creates a circular cut-out style of fillet, the circles will be placed so the upper right part of the circle touches the original sharp corner and are created with the Radius specified. This option should not be used if the slot width and the tool are similar in size. Below left is the vector showing the slot before filleting, on the right is the filleted version using the 'Dog-Bone' option.
test
Vectors before Dog-Bone Filleting
test
Vectors after Dog-Bone Filleting
T-Bone Fillet
This creates a circular cut-out style of fillet, the circles will be created with the Radius specified. This option should be used if the slot width and the tool are similar in size so the slot can grow out to the side to ensure there is space for them to fit. Below left is the vector showing the slot before filleting, on the right is the filleted version using the 'T-Bone' option.
test
Vectors before T-Bone Filleting
test
Vectors after T-Bone Filleting
The placement of the fillet is an interactive process; you can choose which side of the 'corner' the T-bone filet is placed. If you click on a 'corner' the fillet will be placed automatically on the longest side. By clicking to the side of the corner you want the fillet placed you can choose which side the fillet is placed on.
test
vertical edge clicked near the corner
test
Horizontal edges clicked near the corner
Removing Fillets
Fillets can be removed in the same way that we add fillets: move the cursor over the fillet that you wish to remove.
If this fillet can be removed then the cursor shows a cross to indicate that it is possible to remove a fillet:
Clicking removes the fillet:
test
Before removing fillet
test
After removing fillet
When removing fillets the software does not store what kind of geometry the fillet was created from. It always defaults to using straight lines to return the fillet to a sharp corner. As such if the fillet is across multiple spans or is derived from arcs or Bezier curves then it will not go back to its original state and instead it will remove the radius and extend two straight lines to create the new corner.
Usable In Both Views
3D view controls
When applying a fillet within the 3D view, the cursor changes to reflect the fillet type you have selected;
test
Normal Fillet
test
Dog-Bone
test
T-Bone
test
Plasma / Drag Knife
The resulting fillet shape with the current settings are previewed in red when you hover your cursor over a corner;
When this is shown, clicking and dragging the Left Mouse Button outwards from the corner will increase the radius of the resulting fillet and you can decrease this by moving the cursor back towards the corner.
This is reflected by the value changing within the Floating Field. As with other tools, you can enter an explicit value into this on the keyboard.
When De filleting in the 3D View, the cursor will change to show an angle with a cross next to it, with the original 90° corner previewed in red;
If you enter an impossible value, then you will be shown a Limit caution Icon next to the cursor;
test
The cursor will still indicate that this is going to apply the largest
fillet of this type possible for the geometry.
If the corner does not consist of two sides but instead includes bezier curves or Arcs, the fillet tool will indicate that it's not possible to apply a fillet with this strike through Icon;
test
