Create Text
Text/Text in a Box
Switch between standard Text tool and Text in a Box Tool modes.
Entering Text
To enter text:
  • Click in the 2D view to choose the anchor position
  • Enter the text in the Text box
  • Edit the styling options. All changes are automatically applied
Font Selection
Vertical Fonts
Engraving Fonts
Text Alignment
Anchor
  • For new text simply left click in 2D view in the desired location
  • For existing text object, left click the anchor point handle and drag it to the desired location
Text in a Box Mode
The Standard Text tools are replaced with specialist Text In a Box tools.
Bounding Box Dimensions
Margin Size
  • None - Scales text to fit the rectangle width or height of the bounding box
  • Normal - Scales text to fit within 80% of the bounding leaving a 10% border to the left and right.
  • Wide - Reduces the size to 60% of the rectangle width leaving a 20% border to the left and right.
Vertical Stretch
No Vertical Stretch
Stretch Line Space to fit
Stretch Characters to fit
Horizontal Stretch
No Horizontal Stretch
Stretch Spaces between words
Stretch Kerning (space between letters)
Stretch Character size
Editing Text
  • If the Create Text form is open, click the text you wish to edit or
  • If the Create Text form is closed, click the left mouse button on the text in the 2D View to select it before opening this form. The form will now allow you to edit the properties of the selected text.
Spell Checker
The Text tool has a spell checking feature to assist with spelling errors.
  • The software checks the spelling for the user and underlines the misspelled words with red.
  • When an underlined word is clicked. It suggest corrections for the user.
  • There is an add word feature if you want to add a new word.
  • There is a remove word feature if you want to remove a word you added by mistake ( it has to be a word added by the user).
  • The language of the spell checker is the same as the language of the software.
  • All the Software supported languages are supported by the spell checker except for Japanese
Letter Kerning
The interactive kerning and line spacing cursor is shown when placed between letters or lines:
The interactive letter kerning allows default text to be modified so that adjacent pairs of letters sit more naturally together. A typical example is shown above where the capital letters W A V are placed next to each other and the default space is excessive.
Place the cursor between 2 letters and click the Left mouse button to close the gap.
Holding the Shift key and clicking the Left mouse button moves the characters apart.
Holding the Ctrl key when kerning doubles the distance each letter moves on each click.
Holding Shift and Ctrl keys together and clicking the Left mouse button moves the letters closer together in larger increments.
Holding down altwith any of the above combinations will apply the kerning changes between every pair of letters on the line.
Note:
It is only possible to Edit letter Kerning within the 2D view.
Line Spacing
Line spacing can be modified by placing the Edit Text cursor between lines. It will change to the line spacing cursor:
Clicking Left mouse button will move the adjacent lines of text closer together.
Holding the Shift key and clicking the Left mouse button will move the lines apart.
Holding the Ctrl key doubles the distance each line moves on each mouse click.
Holding the Shift and Ctrl keys together and clicking the Left mouse button moves the lines apart in larger increments.
Text Arching
The interactive rotation and movement cursor is displayed when the cursor is placed over either of the Green Handles to indicate that the text can be arced either Upwards or Downwards:
Bend Text Upwards
Bend Text Downwards
Click and Drag the Bottom Green box to arc the text Downwards.
Click and Drag the Top Green box to arc the text Upwards.
The text can easily be dragged back into the horizontal position again.
After arcing text, additional Red and Blue handles are displayed for Rotating and Moving the text.
Moving:
There are two white handles for moving the text, one in the middle of the text, and one in the center of the arc, though that may be off-screen for very shallow arcs.
Rotating:
Clicking and dragging the Red boxes rotates the text around the center point of the arc.
Holding the Ctrl key forces the rotation to be in 15° increments. This allows the text to be positioned exactly on the horizontal or vertical quadrants, even after it may have been moved slightly.
Changing Arc Radius:
Clicking and dragging the Blue boxes changes the radius without moving the arc center.
Usable In Both Views
