Draw Polygon
Interactive Creation
  • Click and hold the left mouse button to indicate the center point.
  • Drag the mouse while holding down the left mouse to required radius.
  • Release the left mouse button to complete the shape.
Quick Keys
  • Left-click and drag out your shape in the 2D View.
  • With the left mouse button still pressed, enter a quick key sequence detailed below.
  • Release the left mouse button.
Default
Example
  • 2 . 5 Enter - Creates a polygon with a radius of 2.5. All other settings as per the form
Specifying Further Properties
  • Value D - Creates a polygon with the diameter specified, with all other properties as per the form.
  • Value S Value R - Create a polygon with the specified number of sides (S) and the outer radius (R)
  • Value S Value D - Creates a polygon with the specified number of sides (S) and the outer diameter (D)
Examples
  • 1 R - Outer radius 1, number of sides as per form
  • 1 D - Outer diameter 1, number of sides as per form
  • 8 S 1 R - An 8 sided polygon with outer radius R of 1
  • 6 S 2 . 5 D - A 6 sided polyon with an outer diameter of 2.5
Exact Size
Click Apply to update the circle
Editing Existing Polygons
To edit an existing polygon select the polygon, edit the parameters and click Apply to update the circle.
Usable In Both Views
