File
New
Creates a New VCarve Pro job.
New from template...
Creates a new job based on existing VCarve Pro job template
Open...
Opens an existing VCarve Pro job
Close
Save
Saves the current VCarve Pro file over the last saved version of the file.
Save As...
Save As Template...
Opens the standard File Save dialog so you can save the current file as a job template.
Increment and Save
Print
Print Preview
Print Setup
Import... ►
Export... ►
Export vectors from the job
Exit
Import
Import Vectors / Bitmaps...
Import Vector or Bitmap data.
Import 3D Model or Component
Export
Printing and Print Preview
The contents of either the 2D or 3D view can be printed using the Print... command on the File menu. Simply select the view you wish to print (2D or 3D) and then click the Print... command. The standard Windows printer dialog allows you to select the printer and adjust its properties. When the OK button in this dialog is clicked, the view will be printed. To adjust the printer settings without printing, you can open the same dialog using the Print Setup... command on the File menu. When used in this way, the OK button on the dialog will store the settings without printing immediately.
The Print Preview... command on the File menu allows you to check the layout of your page before you print. If you are happy with the preview, use the Print... button to begin printing the document directly from the Print Preview page.
