Job Setup - Double Sided
Job Type
Job Size
Aspire only supports job sizes up to a maximum of 25 inches square without tiling.
Z Zero Position
Zero off same side
XY Datum Position
Use Offset
Flip Direction Between Sides
Design Scaling
Modeling Resolution
