Drawing
Move Selection
Join Open Vectors
Distort Object
Redo Operation
Text Selection
Circular Copy
Nest Parts
Trace Bitmap
Interactive Vector Trim
Auto Layout Text
Edit Picture
Draw Star
Create Text
Undo Operation
Draw Arc
Interactive Selection Mode
Import Vectors
Snapping Options Dialog
Grouping and Ungrouping
Overlap Vectors
Group Selected Objects
Draw Ellipse
Object Selection Tools
Crop Bitmap
Set Size
Draw Curve
Mirror
Draw Polygon
Offset Vectors
Copy Along Vectors
Vector Boundary
Fit Curves To Vectors
Vector Texture
Trim Objects
Rotate
Open a File
Draw Circle
Create Fillets
Extend Vectors
Plate Production
Dimensions
Cut Operation
Vector Selection Mode
Draw Line
Node Editing Mode
Weld Vectors
Text On A Curve
Vector Validator
Vector Unwrapper
Measure - Inspect
Ungroup Selection
Array Copy
Copy Operation
Subtract Vectors
Import Bitmap
Convert text to Curves
Create a New File
Save a File
Alignment Tools
Paste Operation
Draw Rectangle
Toolpaths
Tool Database
Moulding Toolpath
V-Carve Toolpath
Preview Toolpaths
Save Toolpaths
2D Profile Toolpath
Chamfer Toolpath
Load Toolpath Template
Estimating Machining Times
Material Setup
Toolpath Tiling Manager
Edit Toolpath
Thread Milling Toolpath
Delete Toolpath
Create Job Sheet
Vector Selector
Duplicate Toolpath
Toolpath Templates
Toolpath Tree
Array Copy Toolpath
Fluting Toolpath
Texture Toolpath
3D Finish Toolpath
Quick Engraving Toolpath
Laser Cut And Fill
Tool Database - Name Format
Female Inlay - Pocket
Toolpath Tabs
Photo V-Carve Toolpath
Inlay Toolpath
3D Rough Toolpath
Prism Carving Toolpath
Recalculate All Toolpaths
Drilling Toolpaths
Merged Toolpath
Material Setup - Flat
Pocketing Toolpath
Laser Picture
Save Toolpath Template
Material Setup - Rotary
Modules
Laser Module
VTransfer
Interface
SketchUp Files
Job Setup - Single Sided
License Dialog
Job Setup - Double Sided
2D View Controls
Document Variables
Options Dialog
View Toolbar
Job Setup Form
Job Setup - Rotary
PDF Export
Migration Dialog
Calculation Edit Boxes
File Types
View Controls
Job Templates
3D View Controls
User Guides
Modelling 3D Rotary Projects
How to Get Started
Crash Handling
2D Design and Management
Frequently Asked Questions
Interface Overview
General Workflow
3D Toolpath Files
3D Design and Management
Post Processor Editing
Creating a Rotary Job
Two-Sided Machining
Rotary Machining and Wrapping
Modeling
Turn and Spin
Slice Model
Create Component from Bitmap
Component Tree
Scale Model Height
Offset Model
Two Rail Sweep
Create Shape
Export Model as an STL File
Emboss Component
Baking Components
Create Component from Visible Model
Create Zero Plane
Create Texture Area
Add Draft to Model
Smooth Components
Sculpting
Component Properties
Clearing or Splitting Components
Extrude and Weave
Level Clipping
Replace Below
Menus
Help
Edit
Gadgets
Right Mouse Click Menu
Model
Toolpaths
View
File
Preinstalled Gadgets
Create Rounding Toolpath
Keyhole Toolpath
Wrapped Fluting Layout
Wrapped Spiral Layout
Drag Knife Toolpath
Job Setup Sheet Editor
Celtic Weave Creator
Layers
Layer Management
Clipart
Clipart Tab
Drawing
Move Selection
Join Open Vectors
Distort Object
Redo Operation
Text Selection
Circular Copy
Nest Parts
Trace Bitmap
Auto Layout Text
Edit Picture
Draw Star
Create Text
Undo Operation
Draw Arc
Import Vectors
Overlap Vectors
Draw Ellipse
Crop Bitmap
Set Size
Draw Curve
Mirror
Draw Polygon
Offset Vectors
Copy Along Vectors
Vector Boundary
Vector Texture
Trim Objects
Rotate
Open a File
Draw Circle
Create Fillets
Extend Vectors
Plate Production
Dimensions
Cut Operation
Draw Line
Node Editing Mode
Weld Vectors
Text On A Curve
Vector Validator
Vector Unwrapper
Measure - Inspect
Ungroup Selection
Array Copy
Copy Operation
Subtract Vectors
Import Bitmap
Create a New File
Save a File
Alignment Tools
Paste Operation
Draw Rectangle
Toolpaths
Tool Database
Moulding Toolpath
V-Carve Toolpath
Preview Toolpaths
Save Toolpaths
2D Profile Toolpath
Chamfer Toolpath
Material Setup
Edit Toolpath
Delete Toolpath
Create Job Sheet
Vector Selector
Duplicate Toolpath
Toolpath Templates
Toolpath Tree
Array Copy Toolpath
Fluting Toolpath
Texture Toolpath
3D Finish Toolpath
Laser Cut And Fill
Toolpath Tabs
Inlay Toolpath
3D Rough Toolpath
Drilling Toolpaths
Merged Toolpath
Pocketing Toolpath
Laser Picture
Modules
Laser Module
VTransfer
Interface
SketchUp Files
License Dialog
2D View Controls
Document Variables
Options Dialog
View Toolbar
Job Setup Form
Job Setup - Rotary
PDF Export
Migration Dialog
File Types
View Controls
Job Templates
3D View Controls
User Guides
How to Get Started
Crash Handling
Interface Overview
General Workflow
3D Toolpath Files
Two-Sided Machining
Modeling
Turn and Spin
Slice Model
Component Tree
Scale Model Height
Offset Model
Two Rail Sweep
Create Shape
Emboss Component
Baking Components
Create Zero Plane
Create Texture Area
Add Draft to Model
Smooth Components
Sculpting
Extrude and Weave
Level Clipping
Replace Below
Menus
Help
Edit
Gadgets
Model
Toolpaths
View
File
Keyhole Toolpath
Drag Knife Toolpath
Layers
Layer Management
Clipart
Clipart Tab
Build Date: 12/10/2020, 11:25:19
What's New
Keyboard Shortcuts
Single Page
User Guide
Vectric Website
Tutorial Videos
User Forum
English
German
Italian
Japanese
French
Spanish
Create Zero Plane
Creates a component that is the size of your job setup with a height of Zero.
