Material Settings Dialog
This dialog sets how the model surface is shaded in the 3D view — either a flat colour or a named material texture. It changes the appearance only; it does not affect the size of the job or where the toolpaths cut.
Choosing an Appearance
Pick an appearance from the drop-down list. Choose Solid Color and use the colour picker to set the colour, or choose one of the material textures. The change is applied immediately.
Tip
The dialog closes on its own when you click away from it, so there is no OK button — your choice is applied as soon as you make it.
