New Job Dialog
The Create Job dialog sets up a new piece of material to work on — its size, units and appearance. These dimensions define the working area your design and toolpaths are built within.
Watch tutorial: How to Setup your Sheet
Setting Up a Job
Enter the Width (X), Length (Y) and Thickness (Z) of your material, choose whether to work in inches or millimetres, pick a modeling resolution, and choose an appearance. Click Create to make the job.
Options
Width (X) / Length (Y) / Thickness (Z)
The dimensions of the material block.
Units
Whether the sizes are measured in in or mm.
Appearance
A solid colour or a material texture used to render the model surface.
Tip
Blank, zero or negative sizes are rejected — the offending field is highlighted and the job is not created until it is valid.
