View Toolbar
[object Object]
Snapping Toggle Options
Snap to geometry
Smart Snapping
Snap to Grid
View Controls
Toggle Pan / Twiddle View
Zoom to box
Zoom to drawing
Zoom to selection
Toolpath Drawing Toggle
Toggle 2D Toolpath Drawing
Toggle solid 2D Toolpath Drawing
3D Drawing
Toggle drawing of material block
Tile 2D & 3D View Windows
Stack 2D and 3D View windows vertically
Stack 2D and 3D View windows horizontally
Two-Sided Machining
Turn horizontally from left to right
Turn vertically, end over end
Top side is active, all operations will apply to the Top side.
Bottom side is active, all operations will apply to the Bottom side.
Toggle Two-Sided View
