How to Get Started
![](https://cdn.sanity.io/images/i7cqi3ri/translated/c45131186f380f21c52e5210d931c063cfd3be6f-243x612.png)
When you first start the program you will see the Startup Task options on the left hand tab and also a list of your 4 most recently opened Aspire parts (this is a rolling list that will be populated each time you run the software and may initially be empty).
When you first start the program you will see the Startup Task options on the left hand tab and also a list of your most recently opened Aspire parts.
The first choice is whether you want to Create a new file or Open an existing one.
Video Tutorials
Online Resources
