Tool Database - Name Format
![](https://cdn.sanity.io/images/i7cqi3ri/translated/4b0a99d5efebcd0f3be1022a829500199cdd4440-618x267.png)
Format
The template contains variables of the format {Variable Name}
which will be substituted by their real value for the tool.
- For example,
{Tool Type}
will be End Mill for an End Mill tool and Ball Nose for a Ball Nose tool. - We can optionally format those the values in certain ways using modifiers
{Variable Name|Modifier}
. In the above example,{Tool Type|U}
would result in END MILL or BALL NOSE.
- We have materials MDF and Oak and a tool with the name template
. The tool is an 0.5 inch End Mill. - When the MDF material is active, the name of the tool becomes End Mill 0.5 MDF. When it Oak is active, it becomes End Mill 0.5 Oak.
- When the tool is selected for toolpathing, the name of the tool with the correct material name will be used allowing you to see straight away which variant of the tool you've used.
Set as Default
Any tool which does not have the default name format for its type can be restored using the next to the format field.
Update existing tools
- Rename all the tools that had a matching name.
- Rename all the tools indiscriminantly.
List of Variables
This is the full list of variables that can be used in the format.
In some cases, we may not be able to find a valid value. For example, if we use the {Material Name}
when no material is active. In that case, we will simply keep the variable name in the tool name. This should not happen if the tool is valid / suitable for toolpath selection.
Variable | Type |
Geometry | |
| String |
| String |
| String |
| Float |
| Float |
| Float |
| Float |
| Float |
| Integer |
| Integer |
Cutting Parameters | |
| String |
| String |
| Float |
| Float |
| Float |
| Float |
| Integer |
| Float |
| Float |
Feeds & Speeds | |
| String |
| Float |
| Float |
| Integer |
| String |
| Float |
| Float |
| Integer |
Material | |
| String |
Machine | |
| String |
| String |
| String |
| String |
List of Modifiers
Variable Type | Modifiers |
String | U Uppercase Example: |
| L Lowercase Example:
Float | 00.00 Padding / Decimal Points
| F Fraction in inches Example (for an 1/8 inch diameter):
