User Guide
General Workflow
Aspire has been developed to allow the production of decorative and artistic dimensional carved parts. As well as drawing and modeling tools, it includes both 2D and 3D machining, along with 3D V-Carving / 3D Engraving to allow a huge variety of jobs to be produced as quickly and easily as possible.
Workflow Logic
  1. Layout 2D Design:
    1. Import Vectors
    2. Draw Vectors
    3. Import Bitmaps
  2. Create 3D Components:
    1. Create shapes from 2D design vectors
    2. Create (texture) shapes driectly from bitmaps
    3. Import 3D Clipart and models from other CAD systems
  3. Manipulate 3D components to create the 3D composite model using the component tree:
    1. Change location, depth, size, angle etc.
    2. Group and change relationship to other components
  4. Create 2D, 2.5D or 3D toolpath:
    1. Create or edit vector boundaries for toolpaths
    2. Specify tool details for each strategy
  5. Preview Final Part:
    1. Visualize the part as it will actually look.
    2. Create proof images for customer.
    3. Check estimate for cutting time
  6. Save the CNC Code: Save the final cut file to send to the CNC machine
Design
Aspire includes drawing and editing tools that allow designs to be created and modified. Functions for vector creation and editing are very easy to use and multiple design elements can also be drawn or imported, scaled, positioned and interactively edited to make a new design. Text can also be created using any TrueType or OpenType fonts installed on your computer, or the single stroke engraving fonts supplied with the software.
Model
Once the 2D design is ready, 3D components can be created from 2D Vector drawings. This will probably involve adding and changing 2D artwork a bit as the 3D design evolves, so Aspire's interface makes the drawing and modeling tools easily accessible.
In addition, existing 3D models can be imported to be incorporated into a design, these could be files previously created in Aspire, 3D Clipart that has been purchased and downloaded or models from other CAD design systems in a supported format.
Toolpath
A comprehensive set of 2D, V-Carving, Engraving and 3D toolpath strategies provide you with efficient ways to use your tooling to carve the finished part. This process is usually relatively independent of drawing or modeling (although toolpaths are often created directly from some artwork or 3D composite models). Aspire provides simple interface buttons to toggle screen layout to assist the shift in focus from design to toolpathing.
Output
Finally you can use Aspire's large selection of post-processors to save toolpaths in precisely the format that your particular CNC machine tool requires.
Interface Overview
  1. The Main Menu Bar (the Drop Down Menus) along the top of the screen (File, Edit, Model, Toolpaths, View, Gadgets, Help) provides access to most of the commands available in the software, grouped by function. Click on any of the choices to show a Drop-Down list of the available commands.
  2. The Design Panel is on the left side of the screen. This is where the design tabs can be accessed and the icons within the tabs to create a design.
  3. The Toolpath Tab is on the right side of the screen. The Top section of the toolpaths tab houses all of the icons to create, edit and preview toolpaths. The bottom half shows you toolpaths that you have already created.
  4. The 2D Design window is where the design is drawn, edited and selected ready for machining. Designs can be imported or created directly in the software. This occupies the same area as the 3D View and the display can be toggled between the two using F2 and F3 or the tabs at the top of the window.
  5. The 3D View is where the composite model, toolpaths and the toolpath preview are displayed.
  6. If you wish to see the 2D and 3D views simultaneously, or you wish to switch your focus to the Toolpaths tab at a later stage of your design process, you can use the interface layout buttons (accessible in the 2D View Control section on the Drawing Tab) to toggle between the different preset interface layouts.
Managing the Interface
Accessing Auto-hidden tabs
2D Design and Management
Ultimately the point of all these different types of objects is to allow you to create the toolpaths you need to cut the part you want on your CNC. This may mean that they help you to create the basis for the 3D model or that they are more directly related to the toolpath such as describing its boundary shape. The different applications and uses for these 2D items mean that organization of them is very important. For this reason Aspire has a Layer function for managing 2D data. The Layers are a way of associating different 2D entities together to allow the user to manage them more effectively. Layers will be described in detail later in the relevant section of this manual. If you are working with a 2 Sided project you can switch between the 'Top' and 'Bottom' sides in the same session, enabling you to create and edit data on each side, and using the 'Multi Sided View' option you can view the vectors on the opposite side. 2 Sided Setup will be described in detail later in the relevant section of this manual.
Vectors
Vectors are lines, arcs and curves which can be as simple as a straight line or can make up complex 2D designs. They have many uses in Aspire, such as describing a shape for a toolpath to follow or creating designs. Aspire contains a number of vector creation and editing tools which are covered in this manual.
As well as creating vectors within the software many users will also import vectors from other design software such as Corel Draw or AutoCAD. Aspire supports the following vector formats for import: *.dxf, *.eps, *.ai, *.pdf, *skp and *svg. Once imported, the data can be edited and combined using the Vector Editing tools within the software.
Bitmaps
To make 3D models simple to create, Aspire uses a method which lets the user break the design down into manageable pieces called Components. In the 2D View a Component is shown as a Grayscale shape, this can be selected and edited to move its position, change its size etc. Working with the Grayscale's will be covered in detail later in this manual. As with bitmaps, many of the vector editing tools will also work on a selected Component Grayscale.
3D Design and Management
The 3D View
The Composite Model
Aspirehas been designed to work in a way which enables the user to easily create even very complex projects. In any situation, the best approach to producing something complicated is to break it down into smaller pieces until a level of simplicity is reached that can be understood and managed. In Aspirethis is achieved by letting the user work with pieces of the design which are combined to make the finished part. In the terminology of the software these pieces are called Components. To help organize the Components they are assigned to Levels. Step by step, Components and Levels can be created and modified until you have all the elements you need. In the images below you can see an example of how this might work. On the left you can see the separate component for a model of a bunch of grapes and on the right you can see these positioned to make the complete part - we call this resulting combination the Composite Model.
test
test
  1. Use a modeling tool to create shapes from 2D vectors.
  2. Import a pre-created 3d model - either a model previously created in Aspire or from another source such as a clipart library or a different modeling package.
  3. Create a 'texture' Component from a bitmap image.
  4. Use the Split Components Tool to break an existing Component into multiple pieces.
Dynamic Properties
Combine Modes
test
test
test
Note:
Add
test
test
Subtract
test
test
Merge
test
test
Low
test
test
Level Mirror Modes
  • Left to Right
  • Right to Left
  • Top to Bottom
  • Bottom to Top
  • Top Left Quadrant
  • Top Right Quadrant
  • Bottom Left Quadrant
  • Bottom Right Quadrant
Multi Sided View
3D Toolpath Files
Files from Vectric's Cut3D, PhotoVCarve and Design and Make Machinist that include 3D toolpaths can be imported into Aspire using the main menu command: File ► Import ► PhotoVCarve, Machinist or Cut3D Toolpaths.
The 3D file must first be scaled to the required size before toolpaths are calculated, and then the complete file saved ready for importing into Aspire. These files can only be moved and positioned inside Aspire but cannot be scaled.
Positioning
test
Origin for the 3D data at X0 Y0
test
Grayscale image moved to middle of job
test
2D window showing thumbnail previews, text and decorative border
test
3D window previewing the completed job
Options
Rotary Machining and Wrapping
Aspire can 'wrap' flat toolpaths around a cylinder to provide output to CNC machines which are configured with a rotary axis / indexer. The image below shows a flat toolpath wrapped around part of a cylinder.
Aspire can also visualize a wrapped model within the program by drawing the shaded composite model wrapped.
test
Wrapped toolpaths
test
Cross section of a table leg modeled flat
test
Toolpath wrapping switched on
Aspire also has the ability to draw the toolpath simulation wrapped. Although this is very useful for getting a feel for how the finished product will look, it is important to realize that the wrapped simulation may not be a 100% accurate representation of how the finished product will look. An example of potential difference would be if you drilled holes in your rotary job. In the actual work piece these will obviously just be round holes, in the wrapped simulation these may appear as distorted ovals due to the 'stretching' process which takes place when we wrap the flat simulation model for display.
It is important to realize that there are a huge number of possible combinations of machine controller and axis orientations for rotary axis / indexers. This means it is impractical for Vectric to supply a pre-configured post-processor for every possible combination as standard. We include some wrapping post-processors in the default post-processor list as standard.
We also ship a copy of those post-processors in the Application Data Folder which can be accessed from the File MenuOpen Application Data Folder.
The example below uses wrapped post-processors in sub-folder '05-Wrapped' under C:\ProgramData\Vectric\Aspire\V[ProductVersion]\PostP\05-Wrapped.
Examining these posts may be helpful if you need to configure a post of your own. If Vectric have not supplied as standard a post for your machine configuration please refer to the Post Processor Editing Guide accessible from the Help menu of the program for information on how to configure a post-processor and also look at the standard rotary posts Vectric supply.
Creating a Rotary Job
XY Origin
  • In a job with horizontal orientation (Along X Axis), the X offset will correspond to the length of the cylinder, and the Y offset will be a point along its circumference.
  • In a job with vertical orientation (Along Y Axis), it's the opposite. The Y offset will correspond to the length of the cylinder, and the X offset will be a point along its circumference.
Orientation
Z Origin
Tip:
Vector Layout
Choosing stock material
If the design was created without those considerations in mind, the blank size can always be adjusted in the Job Setupform.
Importing Full-3D models
Overview
  1. Setting-up rotary project
  2. Choosing file for import
  3. Orientating the model in material block
  4. Scaling the model
  5. Finishing the import
Setting up a rotary project
To start the importing process, use Import a Component or 3D Model tool from the Modelling tab
test
test
The same model imported without distortion
test
3-axis rotary machining, tool correctly positioned
test
3-axis rotary machining, tool side is touching the stock
Scaling imported model
Finishing import
Importing Flat Models
If the imported model is not aligned with any of the axes, it may be necessary to use Interactive Rotation. The default option - XYZ View - disables interactive rotation. That means that 3D view can be twiddled with a mouse. Selecting other options enables rotation around specified axis.
First, create the cove vectors using Draw Line/Polyline tool. Those will run along the wrapped axis at both ends of the design. Snapping may be useful to ensure that the created line starts and ends at the wrapped boundaries.
To start, create a line parallel to rotation axis that is 9 inches long. Now select the created flute vector and then select one of the cove vectors while holding down Shift. Then use Copy Along Vectors tool to create 9 copies. The original flute vector may now be removed as it is no longer necessary. Note that first and last copy are both created on wrapped boundaries. That means they will coincide, so one of them can be removed. As the last step select all flute vectors and press F9 to place them in the center of design.
Creating rotary toolpaths
The process of creating 2D rotary toolpaths is very similar to creating toolpaths for Single- and Double- models. This example will use the profile toolpath on the cove vectors. To create the toolpath, select the cove vectors and click on the Profile Toolpath from
test
Toolpath for coves of the column
test
Toolpath for flutes of the column
Contrary to single- and double- sided simulation, rotary simulation is not 100% accurate. For example round holes will appear in rotary view as oval ones, but obviously will be round when part is actually machined.
Although the design can be considered to be finished, in practice it is useful to be able to cut-out the remaining stock. This can be realized by making the design slightly longer and adding profile cuts. In this example the blank length was extended by 2 inches using the Job Setup . Existing vectors can be recentered using F9. After that the existing toolpaths have to be recalculated.
The cut-out vectors can be created in the same way as cove vectors. Two extra profiling toolpaths can be created using the suitable End Mill. In this example we used a tab with a 0.5 inch diameter. In order to achieve that, the user can type the following in the Cut Depth box: z-0.25 and then press = and the software will substitute the result of the calculation. Variable 'z' used in the formula will be substituted by the radius of the blank automatically by software. It is also important to specify Machine Vectors Outside/Right or Machine Vectors Inside/Left as appropriate. Cutout toolpaths and the resulting simulation has been shown below.
test
Cut-out toolpaths in 2D view
test
Finished part after adding cut-out toolpaths
Spiral toolpaths
All but one of the existing flute vectors can be removed. Select the Draw Line/Polyline and start a new line by clicking at one end of the existing flute. This line needs to be made along the wrapped axis with the length being 3 times the circumference of the job. In this example that means typing 90 into the Angle box and typing y * 3 into the Length box and pressing =. If the wrapped axis is not the Y axis, but rather the X axis, then the above formula should be x * 3.
test
Vectors used to create spiral flutes
test
Spiral toolpaths in flat view
Once the flute vectors are ready, the toolpath can be created again using the Fluting Toolpath. An important thing to note, is the difference between the appearance of spiral toolpaths in the wrapped and flat view. By clicking on Auto Wrapping one can switch from wrapped rotary view to flat view and back again.
Modelling 3D Rotary Projects
A simple way to start with 3D rotary models is to use add pieces of decorative clipart that is provided with Aspire. This process is very similar to adding clipart to single- or double- sided project, however there are some additional considerations that are specific to wrapped rotary machining.
To start, switch to the Clipart tab. Then choose a piece of clipart and drag and drop it into the workspace. Aspire will show following message:
test
As can be seen, the model contains only the selected decorative piece on the flat plane. Although the column is obviously a cylindrical solid, so far we only used 2D toolpaths to carve details on the surface of cylinder. So the fact that machined piece is a cylindrical solid, derives only from fact that the blank is a cylindrical solid itself. Aspire allows the 3D model to also describe a solid body.
In this example the intent is to only place a decorative piece on the surface, rather than define body of the column. Aspire can see that we did not model a body and we are placing a piece of clipart, that is likely to be placed at the surface. By responding 'Yes' to the message we can confirm that it is our intent to use the component to decorate a surface.
More clipart can be placed as desired. Then the 3D view can be inspected. Once design is finished it is time to create toolpaths. In order to create 3D roughing toolpath, use 3D Rough Toolpath. Then create 3D finishing toolpath, using 3D Finish Toolpath. Select settings that are most appropriate for given application, while remembering which axis is rotating. The choice of axis may be particularly important if rotation axis speed is slower than linear axis.
Making a tapered column
Double-click zero plane component to open Component Properties. Enter 0.8 in the Base Height box. Select Tilt option. Click Set button in Tilt section, then switch to 2D view and then click in the middle left and then in the middle right. Set angle to 3 degrees.
Since the modelling plane was adjusted for placing component on the surface, it needs to be adjusted again, so the component body is not 'inflated'. To do that open Material Setup form. Adjust modelling plane by moving slider down, until Gap Inside Model is 0.
After modelling a tapered shape, the 3D model of column will have a desired shape. However clipart pieces in the narrower parts have been distorted, as can be seen below. To fix that, one need to stretch the components in the wrapped dimension, to compensate for distortion.
test
Tapered column with distorted clipart
test
Tapered column with clipart stretched to overcome distortion
Modelling turned shapes
Modelling turned shapes is quite easy. It requires a vector representing a profile of the desired shape and a Two Rail Sweep tool.
Select both of those rails and click Use Selection button. The rails will be highlighted. Then select the profile vector and click apply. Inspect the 3D view to verify the results.
Modelling cross section
Vector Unwrapper is useful when rather than modelling a profile along the rotation axis, it is more intuitive to specify desired cross section. The tool transforms a vector, representing a cross section, into a profile vector that can be subsequently used with Two Rail Sweep tool.
When the shape is created, select it and open Vector Unwrapper. The tool will display a cross hair in place where the rotation axis is crossing the profile and a circle with the diameter of the material block. This will help you determine whether the shape with such cross profile will fit in current material block.
In this example, Use Center of contour option was used. That means that rotation axis will be placed in the centre of vector's bounding box. One can also tick Simplify unwrapped vectors option to fit bezier curves, instead of using series of very short line segments. After apply is pressed, the unwrapped version of the selected cross section will be created, as have been shown below.
The tool automatically creates layer called 'Unwrapped Vectors Drive Rails' on which it places two blue line vectors on job sides, parallel to the rotation axis. In order to extrude the profile, open the Two Rail Sweep tool. Then select top and then bottom rail (left and right when Y axis is rotation axis) and confirm selection by clicking Use Selection button. Rails will become highlighted. Now click on unwrapped vector and press apply. The 3D view will show a hexagonal column, that can be seen at the beginning of this section.
Modeling Plane
Vector unwrapper is not restricted to simple shapes. In principle it is always possible to use convex shapes and certain concave shapes. The example below shows a heart profile unwrapped.
test
Heart-shaped vector and its unwrapped version
test
Extruded heart shape
Modelling 3D spiral features
The workflow for creating spiral toolpaths has been presented in Simple rotary modelling using 2D toolpaths chapter. The basic idea involved creating a line at a proper angle to the rotation axis, that exceeded the 2D boundaries. When 2D toolpath is created based on such a line, it will be wrapped around material cylinder, creating a spiral.
To start, select Draw Line/Polyline tool and draw a horizontal line at the bottom of the job from left to right. If it is desired for the spiral pattern to only fill part of the cylinder length, this horizontal line should be drawn only in th desired location. While the drawing tool is still active, type 90 into Angle box and type y * 4 into Length box and pressing =. We used y * 4 formula so the strip will wrap 4 times. Then press Add button to add a vertical segment.
The line that we just created will form a bottom of the strip. Now copy this line and place line so its bottom left end coincides with top left corner of 2D job. This line will form a top of the strip. Then make another copy and place it in the middle. This middle line will be used later to position our design within strip. All three lines have been shown below.
test
test
Easiest way to achieve that, is to create a textured component. To do that, select the design in the component tree and activate the Create Texture Area tool. This example used the default settings of the tool. The tool will create a new component that will fill the whole 2D job boundaries. The component itself will be filled with the design in tiled manner. Now use Set Size tool to resize textured component to match the strip size.
Now the component have to be rotated and moved to fit between the lines be have drawn at the beginning. This process can be made easier by utilizing Copy Along Vectors tool. To proceed, activate the tool and select the textured component first, then select the middle line in the strip while holding Shift. Make sure that Align objects to curveoption is selected and use Number of copies option. Since our strip has already have a correct size, we only need one copy. However the tool would place the middle of our component at the beginning of the line only. If enter 3 as the number of copies, then the tool will place two copies of component at each end and in the middle. Afterwards copies at the ends can be simply deleted. The picture below shows the strip in the 3D view after being correctly positioned.
test
test
Note:
The last step is to make column endings. For that purpose third level was created, with Combine Mode set to Merge. This way the spiral pattern will be 'hidden' at the ends. A circular 3D tab clipart was placed at each end, and stretch vertically to match the job boundaries.
Modelling twisted shapes
This section will show how to create twisted shapes, using combination of level-wrapping and Vector Unwrapper tool.
In this example a new rotary job was created, with diameter of 6 inches and length of 20 inches, rotating around X axis. To start, we need a cross-section vector. In this example a 5-armed star was used. To create a star, we can use Draw Star tool. This example used Outer Radius of 3 inches, to match the radius of the material.
The next step is to unwrap the cross section. In the case of star however, the center is not the same as center of star's bounding box. To find the real center, one can draw line from two of the star corners. Then open Vector Unwrapper and select the star. Then drag rotation center and snap it to the intersection of the lines, as can be seen below.
test
Using Vector Unwrapper with the star-shaped vector
test
Rails and uwrapped star
Once the star is unwrapped, we need to create rails, that will make spiral when wrapped. To do that, select Draw Line/Polyline tool and draw a horizontal line at the bottom of the job from left to right. While the drawing tool is still active, type 90 into Angle box and type y * 2 into Length box and pressing =. We used y * 2 formula so the star will make 2 revolutions Then press Add button to add a vertical segment. Finally, start a new line that connects the horizontal and vertical lines, forming a triangle. Once this line is created, horizontal and vertical lines can be removed.
To overcome that, select both rails, open Draw Rectangle tool and press Create. This will create a bounding box containing the rails. Now, write done the size of the box and save current project. Then create a new single-sided project with the slightly bigger than the bounding box. Use Import Vectors option from the main menu and select previously selected file. Now select the rails and press F9 to center them.
Now use Two Rail Sweep tool. When component is ready, save the file.
Now re-open the original rotary project. Use Import Component and select single-sided project created in the step above. Move the component to the desired location. Then, create new level, move the component there and enable wrapping.
One can simply treat side cross section as rails and use Two Rail Sweep tool, placing half cross sections at appropriate locations. This way half of the leg can be modelled very quickly, with the result that can be seen below (using flat 3D view).
In order to use the created model in rotary project, we need to export and then import it back. Although it is possible to do this with two sessions of Aspire, it can also be done within a single session with rotary project. To export the leg model, make sure no other components are visible (including the automatically added zero plane) and open Export Model tool while holding down Shift. Pressing Shift allows to open the export tool in single-sided, rather than rotary mode.
Since half of the leg was modelled, Close with inverted front option was used. The resulting STL mesh can be seen below.
Once component is exported, it can be re-imported as Full 3D model. The model wil have a seam, in the place were two halfs were merged. This can be removed using smoothing function of Sculpting tool.
Traitement post-processeur
Que fait le post-processeur ?
G-Code Output
T1 M6
G17
G0 Z4.5000
G0 X0.0000 Y0.0000 S12000 M3
G0 X2.4567 Y7.8342 Z0.2500
G1 Z-0.0500 F5.0
HPGL Output
IN;PA;
PU2496,7960;
PD2496,7960;
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
PU2496,7960;
PU2496,6096;
Sections du post-processeur
File Comments
+ History
+ Who When What
+ Tony 14/07/2006 Written
Global File Statements
Statement
Result
FILE_EXTENSION="txt"
UNITS="MM"
PRINT_DIRECT="YES"
RAPID_PLUNGE_TO_STARTZ="YES"
ROTARY_WRAP_Y=A
ROTARY_WRAP_X=B
INVERSE_TIME_MODE="YES"
Rotary: Enables / Disables output of the feedrate F in Inverse Time Feed Mode. In this mode, we're expected to complete a move in one divided by the F number of minutes.
In GCode, this would G93 to switch on, or G94 to switch off and use units mode.
LASER_SUPPORT = "YES"
Indicates that this post-processor supports laser toolpaths (if the Laser Module is installed).
Tape Splitting Support
For example a command of:
would lead to...
Output will be split into multiple files of a maximum of 1000 lines (+ however many lines in there are within the footer section of the post processor), if a retract move exists after line 900 (1000 – 100), the file will be split at that move. If the file was called "toolpath" the split files would be named toolpath_1.tap, toolpath_2.tap etc. The first toolpath output will be "toolpath_ 1.tap" there will be no file named "toolpath" without an index number, (as INDEX_ON_FIRST_FILE= YES is used), unless the file was less than 1000 lines long, in which case the file would not be split.
Line Terminating Characters
LINE_ENDING="[13][12]"
Block Numbering
Statement
Result
LINE_NUMBER=0
LINE_NUMBER_INCREMENT=10
LINE_NUMBER_MAXIMUM=99999
Variables
Variable Name
Output using
Value
Example File
FEED_RATE
[F]
Current Feed Rate.
CUT_RATE
[FC]
Current Cut Feed Rate.
CNCShark-USB_Arcs_inch.pp
PLUNGE_RATE
[FP]
Current Plunge Feed Rate.
SPINDLE_SPEED
[S]
GCode_arc_inch.pp
POWER
[P]
grbl_mm.pp
TOOL_NUMBER
[T]
Current Tool Number.
PREVIOUS_TOOL_NUMBER
[TP]
Previous Tool Number.
NC-Easy.pp
LINE_NUMBER
[N]
Line Number.
TOOL_NAME
[TOOLNAME]
Name of Current Tool.
MaxNC_inch.pp
TOOL_NOTES
[TOOL_NOTES]
Busellato_Jet3006_arc_inch.pp
TOOLPATH_NAME
[TOOLPATH_NAME]
Name of Current Toolpath.
Viccam_ATC_Arcs_inch.pp
TOOLPATH_FILENAME
[TP_FILENAME]
ez-Router_inch.pp
TOOLPATH_DIR
[TP_DIR]
Woodp_arc_mm.pp
TOOLPATH_EXTENSION
[TP_EXT]
Toolpath File Extension.
TekcelE_Arc_ATC_3D.pp
TOOLPATH_PATHNAME
[PATHNAME]
Toolpath Folder Pathname.
WinPC-NC_ATC_Arcs_mm.pp
X_POSITION
[X]
GCode_arc_inch.pp
Y_POSITION
[Y]
GCode_arc_inch.pp
Z_POSITION
[Z]
GCode_arc_inch.pp
A_POSITION
[A]
ARC_CENTRE_I_INC_POSITION
[I]
ARC_CENTRE_J_INC_POSITION
[J]
ARC_CENTRE_I_ABS_POSITION
[IA]
Isel_arc_mm.pp
ARC_CENTRE_J_ABS_POSITION
[JA]
Isel_arc_mm.pp
ARC_START_X_POSITION
[ArcStartX]
TextOutput_Arcs_mm.pp
ARC_START_Y_POSITION
[ArcStartY]
ARC_MID_X_POSITION
[ArcMidX]
ARC_MID_Y_POSITION
[ArcMidY]
ARC_MID_X_INC_POSITION
[ArcMidXI]
ARC_MID_Y_INC_POSITION
[ArcMidYI]
ARC_RADIUS
[Radius]
The radius of an arc.
Bosch_ATC_Arcs_mm.pp
ARC_ANGLE
[Angle]
The angle of an arc.
Generic HPGL_Arcs.pp
X_HOME_POSITION
[XH]
CAMTech_CMC3_mm.pp
Y_HOME_POSITION
[YH]
CAMTech_CMC3_mm.pp
Z_HOME_POSITION
[ZH]
CAMTech_CMC3_mm.pp
SAFE_Z_HEIGHT
[SAFEZ]
EMC2 Arcs(inch)(*.ngc)
WRAP_DIAMETER
[WRAP_DIA]
X_LENGTH
[XLENGTH]
Length of material in X.
Y_LENGTH
[YLENGTH]
Length of material in Y.
Z_LENGTH
[ZLENGTH]
Length of material in Z.
X_MIN
[XMIN]
MaxNC_inch.pp
Y_MIN
[YMIN]
MaxNC_inch.pp
Z_MIN
[ZMIN]
MaxNC_inch.pp
X_MAX
[XMAX]
MaxNC_inch.pp
Y_MAX
[YMAX]
MaxNC_inch.pp
Z_MAX
[ZMAX]
MaxNC_inch.pp
X_ORIGIN_POS
[X_ORIGIN_POS]
Origin Position in X.
Y_ORIGIN_POS
[Y_ORIGIN_POS]
Origin Position in Y.
Z_ORIGIN
[Z_ORIGIN]
XY_ORIGIN
[XY_ORIGIN]
X, Y Origin.
TOOLS_USED
[TOOLS_USED]
TOOLPATHS_OUTPUT
[TOOLPATHS_OUTPUT]
TOOLPATH_NOTES
[TOOLPATH_NOTES]
FILE_NOTES
[FILE_NOTES]
File Notes (Edit > Notes).
TIME
[TIME]
File creation time.
DATE
[DATE]
File creation date.
DWELL_TIME
[DWELL]
Mach2_3_Arcs_inch.pp
PRODUCT
[PRODUCT]
TOOL_DIAMETER
[TDIA]
Tool diameter.
INVERSE_TIME
[FI]
Rotary: Current Inverse Time Rate
AvidCNC_WrapX2A_G93_inch.pp
Format of Variables
where
  • MX = Multiplier Value.
A typical variable
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
VAR
Z_HOME_POSITION
ZH
A
Z
F
1.0
-1
  2. Variable Name.
  3. Equals Sign.
Formatting the Output Value
Flag
Function
Default (without flag)
Left Justify the output
Values are right justified
0
Values is always output with a separator character ( in practive this would only change the output value if the value is set to output integer values only)
Default
Example
VAR LINE_NUMBER = [N|A||1.0]
VAR LINE_NUMBER = [N|A|N|1.0]
VAR FEED_RATE = [F|A||1.0]
VAR PLUNGE_RATE = [FP|A||1.0]
VAR CUT_RATE = [FC|A||1.0]
VAR X_POSITION = [X|A||1.0]
VAR Y_POSITION = [Y|A||1.0]
VAR Z_POSITION = [Z|A||1.0]
VAR X_POSITION = [X|A|X|1.3]
VAR X_POSITION = [X|A|X|1.4]
VAR X_MIN = [XMIN|A||1.3]
VAR Y_MIN = [YMIN|A||1.3]
VAR Z_MIN = [ZMIN|A||1.3]
VAR X_MAX = [XMAX|A||1.3]
VAR Y_MAX = [YMAX|A||1.3]
VAR Z_MAX = [ZMAX|A||1.3]
VAR X_MIN = [XMIN|A|X|1.3]
Valeur du multiplicateur
Blocs de post-processeur
HEADER
begin HEADER
"Commands"
Home Position Information
  • Home X = [XH]
  • Home Y = [YH]
  • Home Z = [ZH]
  • Tool Number = [T]
  • Tool name = [TOOLNAME]
Initial cutting speeds
Spindle Speed
  • Spindle Speed = [S] R.P.M.
TOOLCHANGE
begin TOOLCHANGE
"Commands"
  • Previous Tool Number = [TP]
  • Tool Number = [T]
NEW_SEGMENT
begin NEW_SEGMENT
"Commands"
INITIAL_RAPID_MOVE
begin INITIAL_RAPID_MOVE
"Commands"
RAPID_MOVE
begin RAPID_MOVE
"Commands"
FIRST_FEED_MOVE
begin FIRST_FEED_MOVE
"Commands"
FEED_MOVE
begin FEED_MOVE
"Commands"
FIRST_CW_ARC_MOVE
begin FIRST_CW_ARC_MOVE
"Commands"
"Commands"
FIRST_CW_HELICAL_ARC_MOVE
"Commands"
CW_ARC_MOVE
begin CW_ARC_MOVE
"Commands"
CW_HELICAL_ARC_MOVE
begin CW_HELICAL_ARC_MOVE
"Commands"
FIRST_CCW_ARC_MOVE
begin FIRST_CCW_ARC_MOVE
"Commands"
"Commands"
"Commands"
CCW_ARC_MOVE
begin CCW_ARC_MOVE
"Commands"
begin CCW_HELICAL_ARC_MOVE
"Commands"
FOOTER
begin FOOTER
"Commands"
Sections de support des jets
JET_TOOL_POWER
begin JET_TOOL_POWER
"Commands"
JET_TOOL_ON
begin JET_TOOL_ON
"Commands"
JET_TOOL_OFF
begin JET_TOOL_OFF
"Commands"
Autres sections moins fréquemment utilisées
FEED_RATE_CHANGE
begin FEED_RATE_CHANGE
"Commands"
FIRST_PLUNGE_MOVE
begin FIRST_PLUNGE_MOVE
"Commands"
PLUNGE_MOVE
begin PLUNGE_MOVE
"Commands"
RETRACT_MOVE
begin RETRACT_MOVE
"Commands"
DWELL_MOVE
begin DWELL_MOVE
"Commands"
Caractères spéciaux
  • [10] Outputs a line feed.
Exemple : Ajout de commandes de changement d'outil
Exemple : Changement de l'extension de fichier
To do this:
POST_NAME =
FILE_EXTENSION =
and alter these accordingly.
FILE_EXTENSION = "tap"
to make them read:
FILE_EXTENSION = "nc"
Trucs et astuces
