User Guide
- 2D Design and Management
- Interface Overview
- Rotary Machining and Wrapping
- Creating a Rotary Job
- Simple Rotary Modelling using 2D Toolpaths
- Post-Processor Editing
Ultimately the point of all these different types of objects is to allow you to create the toolpaths you need to cut the part you want on your CNC. This may mean that they help you to create the basis for the 3D model or that they are more directly related to the toolpath such as describing its boundary shape. The different applications and uses for these 2D items mean that organization of them is very important. For this reason Cut2D Desktop has a Layer function for managing 2D data. The Layers are a way of associating different 2D entities together to allow the user to manage them more effectively. Layers will be described in detail later in the relevant section of this manual. If you are working with a 2 Sided project you can switch between the 'Top' and 'Bottom' sides in the same session, enabling you to create and edit data on each side, and using the 'Multi Sided View' option you can view the vectors on the opposite side. 2 Sided Setup will be described in detail later in the relevant section of this manual.
Vectors
Vectors are lines, arcs and curves which can be as simple as a straight line or can make up complex 2D designs. They have many uses in Cut2D Desktop, such as describing a shape for a toolpath to follow or creating designs. Cut2D Desktop contains a number of vector creation and editing tools which are covered in this manual.
As well as creating vectors within the software many users will also import vectors from other design software such as Corel Draw or AutoCAD. Cut2D Desktop supports the following vector formats for import: *.dxf, *.eps, *.ai, *.pdf, *skp and *svg. Once imported, the data can be edited and combined using the Vector Editing tools within the software.
Bitmaps
Interface Overview
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/db38899a70b91d810bb485afc819a7b815d01af6-731x500.png)
Managing the Interface
Accessing Auto-hidden tabs
Vectors
Bitmaps
Cut2D Desktop can 'wrap' flat toolpaths around a cylinder to provide output to CNC machines which are configured with a rotary axis / indexer. The image below shows a flat toolpath wrapped around part of a cylinder.
Cut2D Desktop can also visualize a wrapped model within the program by drawing the shaded composite model wrapped.
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/b4371d1e37ab106c06777c6d7696f306eb3543e6-200x175.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/20cc7f644ff150d63e2820d27a16be3e76a4672e-365x400.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/d017e97ac1202e1120c893b8f14405c47f6ace95-319x400.png)
Cut2D Desktop also has the ability to draw the toolpath simulation wrapped. Although this is very useful for getting a feel for how the finished product will look, it is important to realize that the wrapped simulation may not be a 100% accurate representation of how the finished product will look. An example of potential difference would be if you drilled holes in your rotary job. In the actual work piece these will obviously just be round holes, in the wrapped simulation these may appear as distorted ovals due to the 'stretching' process which takes place when we wrap the flat simulation model for display.
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/3791848de282ddee158985b10521d7e384185d19-282x581.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/7b5de66b2e7d4a3e9e9fd669b28d15429f4a786e-372x529.png)
Z Origin
Tip:
XY Origin
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/f0d9d017af1336ad58ae3830b5cb06b501d3cacd-221x96.png)
Orientation
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/13dd064315aecc17ab2360a6695714a4b5c80a69-221x96.png)
Vector Layout
Choosing stock material
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/fa6ac5402221de43ef50be70f9d2a54a73df2b25-600x300.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/e939dea41b1b5c1377ec3d39fb4b9cb259700c2a-999x842.png)
Creating rotary toolpaths
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/f722b9b7001563f47c04f76e0fafc1dd5a86f4ea-775x600.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/6fa6eaa4fbc534545b16cc2af3e0c7e448655ba8-924x673.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/06a50e004ea55a5430bce0f2489588971c289f6b-682x638.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/ee1c4b68f8ea523cd634e4ec971647c7b21dbdd7-973x701.png)
Spiral toolpaths
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/6a20507e984762018d901acc1eb553509be1b2a5-267x710.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/2c3fecb6cbd725551afe1007587cc46a74722135-341x1269.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/714de6ab56efb1d56cd11d9292772144f51f6624-1164x996.png)
G-Code Output
T1 M6
G17
G0 Z4.5000
G0 X0.0000 Y0.0000 S12000 M3
G0 X2.4567 Y7.8342 Z0.2500
G1 Z-0.0500 F5.0
HPGL Output
IN;PA;
PU2496,7960;
PD2496,7960;
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
PU2496,7960;
PU2496,6096;
Post Processor Sections
File Comments
+ History
+ Who When What
+ Tony 14/07/2006 Written
Global File Statements
Statement | Result |
Tape Splitting Support
For example a command of:
TAPLE_SPLITTING=1000 100 "%s_%d.tap" 1 "YES"
would lead to...
Line Terminating Characters
LINE_ENDING="[13][12]"
Block Numbering
Variables
| Tool diameter. | |
Format of Variables
, [Y]
and [Z]
respectively.
where
VO
= Multiplier Value.
A typical variable
VAR
- Equals Sign.
A
= Always output value,C
Formatting the Output Value
| Values is always output with a separator character ( in practice this would only change the output value if the value is set to output integer values only) | When output is set to integer only, separator charactor is not appended to value. |
Default | Example |
Multiplier Value
Post Processor Blocks
HEADER
begin HEADER
"Commands"
Home Position Information
- Home X = [XH]
- Home Y = [YH]
- Home Z = [ZH]
- Tool Number = [T]
- Tool name = [TOOLNAME]
Initial cutting speeds
Spindle Speed
- Spindle Speed = [S] R.P.M.
SPINDLE_ON
begin SPINDLE_ON
"Commands"
TOOLCHANGE
begin TOOLCHANGE
"Commands"
- Previous Tool Number = [TP]
- Tool Number = [T]
NEW_SEGMENT
begin NEW_SEGMENT
"Commands"
INITIAL_RAPID_MOVE
begin INITIAL_RAPID_MOVE
"Commands"
RAPID_MOVE
begin RAPID_MOVE
"Commands"
FIRST_FEED_MOVE
begin FIRST_FEED_MOVE
"Commands"
FEED_MOVE
begin FEED_MOVE
"Commands"
FIRST_CW_ARC_MOVE
begin FIRST_CW_ARC_MOVE
"Commands"
"Commands"
FIRST_CW_HELICAL_ARC_MOVE
"Commands"
CW_ARC_MOVE
begin CW_ARC_MOVE
"Commands"
CW_HELICAL_ARC_MOVE
begin CW_HELICAL_ARC_MOVE
"Commands"
FIRST_CCW_ARC_MOVE
begin FIRST_CCW_ARC_MOVE
"Commands"
"Commands"
"Commands"
CCW_ARC_MOVE
begin CCW_ARC_MOVE
"Commands"
begin CCW_HELICAL_ARC_MOVE
"Commands"
FOOTER
begin FOOTER
"Commands"
Jet Support Sections
JET_TOOL_POWER
begin JET_TOOL_POWER
"Commands"
JET_TOOL_ON
begin JET_TOOL_ON
"Commands"
JET_TOOL_OFF
begin JET_TOOL_OFF
"Commands"
FEED_RATE_CHANGE
begin FEED_RATE_CHANGE
"Commands"
FIRST_PLUNGE_MOVE
begin FIRST_PLUNGE_MOVE
"Commands"
PLUNGE_MOVE
begin PLUNGE_MOVE
"Commands"
RETRACT_MOVE
begin RETRACT_MOVE
"Commands"
DWELL_MOVE
begin DWELL_MOVE
"Commands"
Special Characters
- [10] Outputs a line feed.
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/2021b4d191ef14a5a9d5e181f6f7c1ef407fd719-1509x805.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/09891cd21d1243a82ac5f4ec472bcdcf6052929c-742x931.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/983bb7afddc065915162604ac1f649ec184305f9-1545x934.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/0c7259aef34b56a1aa77573e522dc9e4f2c83dbc-693x464.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/a75e8eba2ec2520c47ee96026c4bc360c7cd1a81-693x518.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/40d8c3fed34f26b6e4d923073b8b9de778b61c09-693x504.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/1821dea7129d6ea085eafee6e6738975f472ed5c-472x178.png)
To do this:
POST_NAME =
FILE_EXTENSION =
and alter these accordingly.
FILE_EXTENSION = "tap"
to make them read:
FILE_EXTENSION = "nc"
Tips And Tricks
